a) does the kit use AC bearings or the stock thrust bearings? (I'm not intimately familiar with their kit)
b) can you thread the screw to accept a nut?
I run a tight gibb on the Z axis with AC bearings and a nut for preload in my conversion and the only backlash I get is induced by the fact that I skimped and only used a single nut on the Z axis. Tax return this year might get me a preloaded nut to replace the simple nut currently on there if the economy doesn't kill me first.
My backlash is between .001 and .002 on a full column move with EMC2's BL compensation running and I haven't touched the preload on the screw since the day I installed the screw.
edit -
Another idea - try locking the head in place (if you still have the gibb lock installed) and jogging the head up till the stepper stalls, then jack up the collar and tighten it. That might put enough downforce on the top of the bearing to give you more preload. Worth a shot?
/edit
Greg
Every day is a learning process, whether you remember yesterday or not is the hard part.
www.distinctperspectives.com
