I was drawing a circle to put a text into it. I only want to use the cad part of bobcad. I found another program cam program to run my plasma machine much easier. The problem I am having is the program really will import Hpgl much better than the only other format it can read dxf. The dxf does not do a very good job with text and I wonder if there is any way to convert my bobcad drawing into a Hpgl file or some other format that might do a better job. Corel will do it fine, but I would like to use bobcad for something since I have it and do not have Corel. Anyway I am using a little program called Sheetcam and for plasma it is way beyond Bobcad in ease of use.
Here is a link to Sheetcam
http://www.sheetcam.com/
Les that builts sheetcam, could give you guys a few pointers in simple plasma cutting cam setups.
