586,102 active members*
2,627 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Arrow 750 Failed to start when I Push start Bottom in fornt of control !
    Jul 2008
    37
    Unhappy Arrow 750 Failed to start when I Push start Bottom in fornt of control !
    Dear Friends,
    It's really amazing for me when I turn On the machine all drives in back of machine are blinking but when I push the bottom to start the machine there no reaction(all emergency bottoms are off).
    My control system is Arrow 750(I have tried to find solution by other topics but no result)
    Please send me your suggestion.
    Thanks in advance for your helpful reply.
    Have a Nice Year in 2009
    Best Regards,
    Jalal
    Jan 2009
    4
    it wouldnt be the first time that button stoped working. try to measure it with an ohm meter.
    also check circuit breakers.
    Jul 2008
    37
    I measured but there was no sign of starting !
    But We are sure that drives are OK so there must be some problem in other parts referring to drawings we couldn't find a solution.
    Thnx
    Jalal
    Jan 2009
    4
    if there is absolutely no sign of starting, then there is problem with power. check voltages on all power supplies.
    check voltage on wire, that connects to power button, under operator panel. then follow that wire, by drawings until you get to defective component.
    is possible, that your CRT stopped working? i saw your topic reffering to that problem...
    drives normally get power when controller boots, or when you switch on the main switch?
    Jul 2008
    37
    I will check and let you know the result.
    Thanks very Much.
    Jalal
  1. Sodick EDM machine Model A7C with MARK XI Control - Start up problem
    By rajappa in forum EDM Discussion General Topics
    Last Post: 02-04-2021, 08:57 PM
  2. one start or two start lead screw
    By Pinhead in forum DIY CNC Router Table Machines
    Last Post: 11-23-2008, 05:32 AM
  3. Single start vs double start ballscrew.
    By darik in forum Linear and Rotary Motion
    Last Post: 03-22-2007, 01:53 AM
  4. Bridgeport Discovery 308 W/SX-15 Control Start up disk needed
    By Richardd in forum Bridgeport / Hardinge Mills
    Last Post: 07-10-2006, 02:07 PM
  5. Help - Spindle Will Not Start from NC Control
    By CSE in forum Bridgeport / Hardinge Mills
    Last Post: 05-24-2006, 05:56 PM
