have a 2001 mini mill i am getting a alarm at start up that the battery is going out needs to be replaced.any info would be helpfull
thanks john
thanks john
Don't turn the machine power off. Save all your programs, Parameters and Settings. Call your HFO to have a technician come and replace the memory battery.
If the battery goes dead you lose everything and if you no longer have the hard copy of Parameters and Settings that came with the machine and have lost the floppy that they are on which also came with the machine you have a problem.
We have some haas mills and ive been told that if you lose the battery or change the battery incorrectly that you could also lose the ladder for the controller also.
Had the same alarm on my 2006 Mini Mill. The batteries are soldered onto the board. Called the local HFO and they sent me a replacement battery for $50.
The replacement battery just plugs into the pin header next to the soldered batteries. problem solved (for now). Next time, i'll have to consider that removing the battery might cause data loss.
Agree with previous poster - back up your parameters and programs asap - its easy.
-J
What is reasoning behind soldering batteries?
I wondered the same thing - HFO service team told me that the battery life depends heavily on the amount of time the machine is Idle. Mine was only 2 1/2 years old when the battery ran out. HFO guy said it will probably have to be replaced multiple times over the life of the mill. Why they soldered two lithium batteries to the board and left a pin header for an external battery is beyond my comprehension.
Just remembered - when i had this alarm, the first thing the tech had me do was delete all the programs in memory (after backing them up of course). Apparently, this alarm can happen when the battery is fine but the memory is full.
:wave:Great Information Guys!!:cheers:
Just a good ol' boy, never meanin' no harm.
Joe
