I was just wondering what you perfer? I see some that are directly over top of the ball screw, and some that are off to the side and drive the ball screw via pulley/belt. What is the Pros/Cons of each?
Thanks, Scott
Thanks, Scott
I took a different approach, very similar to the X3. I securely bolted plates to both sides of the head that extend behind the column. I mounted the screw in the center rear of the column. Worked beautifully, and was very simple to do. Keeps the screw protected from chips and coolant, and doesn't make the mill 5 feet tall.
Regards,
Ray L.
yeah definatly pics, i think i understand what your saying but lets see some photos.
Sounds like a version of cncbridges Z axis.
http://www.cnczone.com/forums/showpo...&postcount=293
I'll have to dig it out and take some. The machine has been in the corner for the last couple of years, since I got a knee mill. Like I said, it's very similar to an X3. In fact, I used an X3 Z axis leadscrew and nut. The motor is mounted to a small plate on top of the column, with a 2.5:1 belt reducer, so the height of the machine is unchanged.
Regards,
Ray L.
The way i will do mine when im feeling better. Is ball screw front center,Stepper motor mounted in the back of column. And use pulley/timing belt system.
And to protect ball screw i will use the samething that protects the table screws on a X2. You can order this rubber from little machine shop.com
I did think about having the ball screw back center column. But i feel it was not for me;since im doing other mods to it. As for side mount acme or ball screws? I just don't like side loading the dovetails.
not a big fan of that. It looks out of place.
Is there anything wrong with mounting it directly over the ball screw, front center?
Here are the picture of my X2. It's ugly (I did it in a day with scrap material), and dirty (the machine's been in the corner gathering dust for over a year, since I got a knee mill), but works very nicely.
Regards,
Ray L.
not bad
That looks quite nice actually. Could use a caring hand though. Why not sell it?
