586,111 active members*
3,186 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Hitachi Seiki Service and Support!!!!!!!!1
Page 10 of 11 891011
Results 181 to 200 of 208
  1. #181
    Mar 2018
    45
    Re: Hitachi Seiki Service and Support!!!!!!!!1
    Hello guys,
    I have Hitachi seiki hs500. In machine right now I can see only 3 axis (xyz) in controller. But 4th b axis module as well as motor also mounted in machine.
    Can any one help me how to enable 4th axis in hitachi seiki hs500?
  2. #182
    Dec 2009
    539
    Hello
    did you get this sorted - its an easy fix but not very upfront - let me know and Ill help you out!
    John
  3. #183
    Mar 2018
    45
    Quote Originally Posted by shas595 View Post
    Hello
    John
    No it's not sorted can you please give me solution?
  4. #184
    Mar 2021
    Hi, can you send me the procedure to reset the turret of a TS15 seicos 21L
    [email protected]
  5. #185
    Sep 2021
    4
    Re: Phone number change!!!
    Hai There,
    We are facing Hitachi seiki C Axis alarm, any way we are not using that axis so if you have C axis Bypass parameter kindly send me [email protected]
  6. #186
    Sep 2021
    4
    Hai Hitachi Man
    We have HS CS 25 Machine with SEICOS 21L, Now we faced C axis Problem but we are not using that C axis(Spindle act as a C axis). I request you to kindly send me the procedure for C axis By pass.
    My mail id is [email protected]
    Thanks in Advance.
  7. #187
    Sep 2021
    4
    Hai All,
    Kindly support me.
    OEM : Hitachiseiki
    NC: SEICOS 21 L
    Required: C axis By pass Parameter.
    My mail id: [email protected]
  8. #188
    Feb 2009
    9
    Any service available for Hcut 203 EDM?
  9. #189
    May 2017
    11
    I have a hitachi seiki Hicell CA20. Great little machine. Tonight I had a live tool dismount from the turret whilst cutting, probably went blunt and too much side load. Anyway, now the turret live tooling coupling is misaligned. it engages / disengages fine. just not where it should be to load and unload the tools wit ATC. It's like it's jumped a tooth or 2 on the belt. I have never seen this before, so not sure where to look. Books have zero info on this. I can only assume there is a proximity switch somewhere with a dog to locate the orient for engaging. Any help appreciated.
  10. #190
    Quote Originally Posted by iamnot.romeo View Post
    I have just got a old Hitachi VM40 with siecos mark II controller. When i power up the machine, i got alarm "battery alarm ---- please change", i change the battery when machine power up, but i can reset this alarm. Can someone help me???
    Is it exactly the same type battery that you changed?
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
  11. #191
    Mar 2022
    6
    DATA HS500
    Quote Originally Posted by vishal105 View Post
    Hello guys,
    Hey guy! Do you have HS500? you can send for me sram backup file and system data save file
    My email: [email protected]
  12. #192
    Mar 2022
    4
    Hi Hitachi Seiki_Man
    My name is Michal I'm from Poland.
    I have a Hitachi Seiki HT20R. The problem is with the main motor yaskawa drive. There are no errors after the machine is started and referenced. When I try to set RPM in YOG mode, the load meter goes to 110% on the Yaskawa panel, the RUN indicator lights up but the engine is stopped. Can you somehow help ??
    Best regards Michał
  13. #193
    Aug 2022
    Quote Originally Posted by seawolf217 View Post
    ok so i got the alarm to go away but now the tool numbers are off... if i call up tool 5, it gives me tool 8... how do i fix that?
    manoj
    How did you get the 2252 alarm to clear?
  14. #194
    Nov 2022
    pudiste comunicarte con jhon?
  15. #195
    Nov 2022
    necesito ayuda o soporte tengo un VA - 45 errores led en placa C mayuscula / c minuscula / F mayuscula si podes ayudarme seria genial
  16. #196
    Aug 2007
    138
    Quote Originally Posted by mecin View Post
    Mecin, you will have to be more specific on what error(s) you are seeing.
  17. #197
    Dec 2009
    539
    Send me a pic of the alarm, sounds like you are saying its CcF?
  18. #198
    I have a Hitachi Lathe HT 20RIII with a Seicos Multi control throwing a flash Error intermittently upon start up. Seems to be getting worse every day. I can usually reboot it a few time and it will start. Any suggestions I cant find anyone that seems to know these machines anymore.
    Ryan
  19. #199
    Dec 2009
    539
    Hello Ryan
    Send me a PM with your email and I’ll help you out
  20. #200
    Jul 2023
    Post Re: Hitachi Seiki Service and Support!!!!!!!!1
    Hello,
    I need the eletric scheme of Hitachi Seiki TF25 – Seicos A10L...
    In fact i just need the electric scheme of the RS232C terminal to exchange data. Does anyone have it?
    Thnak you so much in advence.
    Marisol Delgado.
  1. Did Mori Seiki Buy Hitachi Seiki?
    By Billet Sean in forum Mori Seiki lathes
    Last Post: 05-05-2011, 04:12 AM
  2. Hitachi Seiki Parts, Support and Manuals
    By npkaye in forum News Announcements
    Last Post: 03-09-2011, 12:16 PM
  3. HITACHI SEIKI MACHINES. SERVICE / TECH
    By bob1112 in forum Uncategorised MetalWorking Machines
    Last Post: 09-14-2010, 04:49 PM
  4. Hitachi Seiki tech network - support
    Last Post: 12-29-2008, 10:26 PM
