586,104 active members*
3,427 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Hitachi Seiki Service and Support!!!!!!!!1
Page 11 of 11 91011
Results 201 to 208 of 208
  1. #201
    Dec 2009
    539
    Re: Hitachi Seiki Service and Support!!!!!!!!1
    Quote Originally Posted by MarisolDelgado View Post
    Hello,
    I need the eletric scheme of Hitachi Seiki TF25 – Seicos A10L...
    In fact i just need the electric scheme of the RS232C terminal to exchange data. Does anyone have it?
    Thnak you so much in advence.
    Marisol Delgado.
    Hello
    PM me your email and I can send you a copy of those pages
    John
  2. #202
    Sep 2023
    6
    Hi Hitachi_man. please help
    Hitachi Seiki HT20SII CNC Lathe (Model: HT20S)
    Problem 1. Turret fault.
    The current issue is specific to the turret when calling for a tool via program or MDI. The turret will index fine manually via buttons on front control panel however, when using program of MDI, it throws the machine into an fault condition.
    Problem 2 (new). "SUM CHECK ERROR: BATTERY".
    We are not able to reach the error code page right now because we have a new problem with the battery. I'm not sure if this fuse related somewhere or if the battery is somewhere on the PC board. When I opened the back panel I saw a small LED code "E7 NC Emergency" I guess this is all related to the same cause.
    I am grateful in advance for any help
    I look forward to your replays and thank you.
  3. #203
    Dec 2009
    539
    Quote Originally Posted by sbeg View Post
    Hello!
    What is the control? You can PM your information and I’ll assist
    John
  4. #204
    Nov 2007
    4
    Hello,
    I have a Hitachi Seiki VM 50 with Seicos 10M control.
    We lost some some function in a prior parameter catastrophe and need to reinstall cutter diameter
    compensation. We can insert in the tool page but it does not affect part size or length.
    Thanks for any help.
    Bob
  5. #205
    Sep 2019
    We have a Hitachi Seiki VG55 with the Seiki-Seicos III/A control. This machine came with a Kitagawa rotary unit 4th axis and the motor is starting to fail in the unit, causing over current alarms. We need to get the motor repaired, but disconnecting the cables from the A axis causes all sorts of alarms. This, even though there is an Axis Detach signal on input X0B5 that is supposed to indicate the unit is disconnected.
    If I can't disable the 4th axis the machine is going to be down for as long as it takes to get the motor pulled, repaired and reinstalled. There are some hints of possible parameters to disable the axis in the Seicos manual, but the manual is like reading old electronics service manuals for Japanese audio equipment from the 1970s. The translation leaves much to the imagination.
    Any help how to disable the axis will be greatly appreciated.
    Will
  6. #206
    Dec 2009
    539
    Quote Originally Posted by wshultz View Post
    Will
    Pm me your contact info and I can guide you. There will be some parameters and’s system bits that need changing to completely disable
    John
Page 11 of 11 91011
  1. Did Mori Seiki Buy Hitachi Seiki?
    By Billet Sean in forum Mori Seiki lathes
    Last Post: 05-05-2011, 04:12 AM
  2. Hitachi Seiki Parts, Support and Manuals
    By npkaye in forum News Announcements
    Last Post: 03-09-2011, 12:16 PM
  3. HITACHI SEIKI MACHINES. SERVICE / TECH
    By bob1112 in forum Uncategorised MetalWorking Machines
    Last Post: 09-14-2010, 04:49 PM
  4. Hitachi Seiki tech network - support
    Last Post: 12-29-2008, 10:26 PM
