586,123 active members*
3,324 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Hitachi Seiki Service and Support!!!!!!!!1
Page 2 of 11 1234
Results 21 to 40 of 208
  1. #21
    Nov 2004
    36
    Ok guys, not sure what is going on but I'm not getting any emails or anything so here is my new info...
    www.kmtscnc.com
    316-260-6090
    [email protected]
    I am still here and working on them, and I do still have a huge data base of software and procedures available. Feel free to email or call me direct if you need to!! And check out the website its new and still adding.
  2. #22
    Oct 2006
    Hitachi Seki VM50
    Hello,
    One of customer has bought a second hand Hitachi seki vm50 super productive vertical machining centere from a trader , with out any manuals.
    We are able to power up the machine, but with alarms like AXIS OVER TRAVEL +-, 801 PC LADER SUM CHECK ERROR , 742 EDITING THE PROGRAME, ETC..
    THE SYSTEM IS A SEICOS LAMBDA 10M, WITH NEC DRIVE AND FANUC MOTORS.
    DO YOU THIS MACHINE MANUALS AND PROCEDURE FOR CLEARING THESE ALARMS?
    IF SO PLEASE SEND ME A MAIL.
    D.JOHNSON.
    00919444029066.
    INDIA
  3. #23
    Nov 2004
    36
    The worst of the alarms you have is the check sum, but it is an easy fix. Contact me by phone or email directly and we can get it taken care of. My contact info is on my website at www.kmtscnc.com.
    Josh
  4. #24
    Dec 2006
    4
    i have a problem with a seicos mark 2 control.on starting the system it says pc not ready and then the screen will shange to checksum error.any suggestions???
  5. #25
    Nov 2004
    36
    this is not a big issue. The check sum error can be fixed rather easy. Call me tomarrow at 316-260-6090 and i'll get you through it. shouldn't take more than 5 min's.
  6. #26
    Dec 2006
    4
    Sorry,couldnt Call Next Day Due To A Demise In The Family.when Can I Call You Next And What Time?
  7. #27
    Dec 2006
    4
    josh,
    is it possible to email me the procedure since we have an 11 hour time difference.i called u at 8am your time but u were'nt there.
  8. #28
    Dec 2006
    4
    e-mail id (i forgot)[email protected]
  9. #29
    we have an hs630 , the tool arm doen't seem to grip the tools with much stength ,there is no visible wear but when the arm comes around the tool is flopping around ,i beleave the springs in the arm are worn and the book shows nothing for adjusting ,
    some of the guys claim they are cleaning the oil around the sensors and it works better ,is this possible (sensors)? the door is pretty smashed so coolant and chips do get into the magazine side
    i haven t had a chance to look into it further ,but we have had it throw some tools ,
    it is set for heavy tools
    we have a new arm coming but i was wondering if something is being over looked
    thanks
    curt
  10. #30
    Jan 2006
    4396
    It may not be the Collant or Oil on the Sencors, but a combination of Chips, Wear, and Coolant buildup around the Gripping Finger. Don't forget that most older machines have an Origin in which they have to be loaded (Dimple OUT). If some inexperienced person Loaded it wrong once it posses a problem of throughing tools in the Future. I see a lot of machine abuse around here because people cut corners rushing to get the setup done. Or they simple were not taught correctly. Check for Damage and or Chip Buildup around the Gripping Finger of the Tool Arm. You may be very suprised at what you find.
    BTW: Check the Spring Load Tention by Prying a Tool Holder out Carefully. If it comes out too easy, you know the drill buddy. Replacement which can be a real PITA on older machines. The new ones just break off, LOL
    Cheers :cheers:
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
  11. #31
    Quote Originally Posted by tobyaxis View Post
    Cheers :cheers:
    don t need to
    watching the tool change is enough for me , plus i don't have to pry a tool out ,i just yank it out
    there is no more than typical wear on a machine that age ,
    the springs are probably cooked
  12. #32
    Jan 2006
    4396
    Quote Originally Posted by dertsap View Post
    don t need to
    Most likely dude. Did you get a chance to look at the Keys on the spindle for damage? Their function isn't driving but Orientation is Vital on some of the machines for G76 Fine Boring with a Q Shift.
    I would have to say it is the spring too.
    Toby D.
    Schwarzwald
  13. #33
    Feb 2007
    17
    Hello Hitachi-man, We Have A Hitachi Vertical Machining Center Model Maccmatic 48v / Fanuc 6m. We Have Problems With Atc .
    Can You Send Us The Manual And The Electrical Drawings Of The Control Hitachi ?.
    I Have Someones Manuals Fanuc, Do You Have The Service Manual For The System 6m.
    Best Regards
    Gerardo
  14. #34
    Feb 2007
    45
    Hello Hitachi-man.
    I have a Hitachi-Seiki 4a Ram type turret lathe. Would you happen to have the manuals for it? I also need the feed drive idler gear. I am also looking for a taper attachment for it, plus threading attachment if possible.
    Thanks, Ken
    [email protected]
  15. #35
    Feb 2007
    45
    hitachi seiki
    does this guy answer anyone anymore? I would gladly buy a manual for the 4a...........just not for 250+ like online
  16. #36
    orphaned
    just as the machines have been
  17. #37
    Feb 2007
    45
    orphans
    well at least his phone # is there, maybe he still answers that? Must be a busy man
  18. #38
    Feb 2007
    45
    and his phone # is disco now too. Is this guy still alive?
  19. #39
    Mar 2007
    Hs 630
    Hello Hitachi Man,
    My company currently employs a HS630 Horizontal Machining Cell, for which we have no user manual (an external repair company took it with them after a job!).
    I have been asked to look into the operating pressures of our machines and review these to see if we are over-pressurising unnecessarily.
    I would therefore be most grateful if you could provide me with any information that you deem to be relevant.
    Kind Regards,
    (CNC KPM)
  20. #40
    Feb 2007
    45
    hes not answering in here, not returning email and his phone has been disconnected. I am thinking he is stuck in a lathe somewhere.........
Page 2 of 11 1234
  1. Did Mori Seiki Buy Hitachi Seiki?
    By Billet Sean in forum Mori Seiki lathes
    Last Post: 05-05-2011, 04:12 AM
  2. Hitachi Seiki Parts, Support and Manuals
    By npkaye in forum News Announcements
    Last Post: 03-09-2011, 12:16 PM
  3. HITACHI SEIKI MACHINES. SERVICE / TECH
    By bob1112 in forum Uncategorised MetalWorking Machines
    Last Post: 09-14-2010, 04:49 PM
  4. Hitachi Seiki tech network - support
    Last Post: 12-29-2008, 10:26 PM
