586,058 active members*
4,449 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > Microcontroller based bipolar stepper driver
Page 3 of 3 123
Results 41 to 50 of 50
  1. #41
    Mar 2011
    Wink
    Quote Originally Posted by dandumit View Post
    ok . Thank you for directions !
    First I will build the prototype and I will start to modify it from chopping to sync pwm.
    Second I will investigate the decay scheme. in an2229 it says that it is perfoming fast and slow decay on same phase. Taking in account discussions from this forum it's too nice to be true...
    I will keep you posted.
    most of the above is from Mariss and others but should be a good starting point for a great drive. Gecko's will likely outperform it but for the dedicated diy guy it could be outstanding. as it stands now the psoc reference design is better than allegro but still with many flaws.
    _________________
    cheat codes
    game cheat codes
  2. #42
    Feb 2005
    122
    above application it's based on psoc1. for an amateur it's a good choice. to compete with gecko it's a joke.
    But I repeat it's far better than all the open source designs that I have found on internet. And most interesting it's capable to drive high current motors.
  3. #43
    Mar 2011
    Quote Originally Posted by amplexus View Post
    I'm no Bob Peace or Mariss but I can manage a few things let me know if I can help. At the very least I can keep you amused with unworkable ideas. If you get really stuck try e mailing Bob Peace, he is amazing and his columns are a goldmine of ideas.
    Amplexus
    ciao... Io devo scrivere un algoritmo per il controllo di 2 assi x e y controllati da 2 motori a passo mi servirebbe qualche algoritmo come esempio.. Dovrei farlo in linguaggio c
  4. #44
    Feb 2007
    13
    @ dandumit
    Do you have schematic and source code for working version of psoc 1 available ?
  5. #45
    Feb 2005
    122
    I have to look for them. Has passed some time (one hdd damaged) and I has thinking that nobody it's interested in this solution.
    Again compared with others drivers (even comercial) available it's a good choice.
    DAniel
  6. #46
    Feb 2007
    13
    OK
    Let me know if you find files.
    email [email protected]
    Thanks a lot
  7. #47
    Feb 2005
    122
    Schematic it's here :
    http://www.cnczone.com/forums/603365-post30.html I will find the Kicad source too .
    Application it's exactly the same that given as sample design on Cypress site. Again I will look for them.
  8. #48
    Feb 2007
    13
    1.Thanks for schematics
    2.If you take a look at page 5 AN43679 there is no connection from digital blocks
    to ports ?
    any comment
    thanks
  9. #49
    Feb 2005
    122
    That connections are made at run time and not at design time. At very beginning I had a problem too to understand that. it's because same pwm generators are used to drive a H bridge in both ways.
  10. #50
    Feb 2007
    13
    dandumit
    Thanks a lot
Page 3 of 3 123
  1. New Allegro Bipolar Stepper Driver A3986
    By BCwanderer in forum Open Source Controller Boards
    Last Post: 09-05-2014, 06:46 AM
  2. Unipolar Stepper run with Bipolar Driver
    By bcromwell in forum CNC Machine Related Electronics
    Last Post: 06-21-2013, 03:20 PM
  3. need help to connect microcontroller to stepper driver
    By xinzc28 in forum CNC Machine Related Electronics
    Last Post: 11-07-2008, 09:59 AM
  4. MicroController/DSP based Motion interface
    By Haz in forum CNC Machine Related Electronics
    Last Post: 03-22-2007, 09:54 PM
  5. RQ: Bipolar stepper motor driver circuit
    By elektronchika in forum Stepper Motors / Drives
    Last Post: 12-22-2005, 12:29 AM
