Aussie Adventure 5
Hi All,
I am at it again and building another gantry router. Similar design to all my other machines but improving (hopefully) as I go.
My main goals are to build mass into the machine base and strength into the gantry.
Rather than bodgy up a trolley and the electrics at the end as I usually do I have concentrated a lot of effort earlier in the build so these two components are finished first. The trolley had to be built anyway as this machine was too large to build on a mobile bench that I normally work off.
There is plenty of gussets and later on I put plates front and back and an additional brace on the sides. Being mobile it has to be rigid. The castors are cast iron and rubber coated and rated at 560kg total so they should stand up to the load.
First photos are of the trolley and it has been built on my mobile trolley so some of the photo angles look a bit wierd. The shute down the length of the machine is to collect sawdust/swarf in a chamber to make cleaning easier. I gave up on vacuum systems long ago and now just sweep to the edge of the table and collect from underneath.
cheers,
Rod
Perth, Western Australia
