It is a dogless system. Y-axis for turret was off and tried changing it with grid shift (1850) but couldn't do it. whenever I change 1850 value I need to power it down and re do the Y-axis home. I couldn't seem to get it at center of the part. It's always off center. I must not be doing it correctly. I enabled zero point enable, jog the y-axis close to center about 2mm and press zero return on and zero return y-axis. bit 1 appears on 1815 y-axis. Is is a correct way of I have to find the center position myself and turn on the 1815 myself?
