586,112 active members*
3,081 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > Laser Addition for existing CNC - Possible ?
    Oct 2006
    41
    Chaps, I hope someone can advise me here because ive googled until ive gone blind but cant find a solution to my problem.
    I have a K2 CNC and use it with a router 100% of the time, I need to cut some very fine detail parts though and ive been looking for a laser to do this.
    im planning on cutting 3mm thick acrylic - nothing heavier really and im sure that there are lasers out there that can do it, I just cant find them
    Cheers,
    J.
    May 2004
    162
    Laser for existing CNC
    I have been looking for exactly the same thing. Replace the router with a laser and off we go. Is any American manufacturer looking at this????
    Thanks. Mike
    Apr 2007
    327
    There are so many differences between controlling a laser and a router that it might not be cost effective to try to build a dual purpose machine. The software that controls the laser is probably the biggest obstacle. My laser uses a printer driver to control all of the various parameters - speed, power, etc. The motion system of a laser is much lighter duty than a router and you have a mirror/lens system that isn't very forgiving to the environment that most routers are used in - dust in particular.
    Most lasers have moving tables for the Z, it's much easier than trying to move mirrors or an entire tube, and most routers move the spindle. I am not sure how you would overcome that obstacle.
  1. Gr-408 Addition, Mod. Log
    By automizer in forum Haas Mills
    Last Post: 08-10-2008, 06:46 AM
  2. Rotating axis addition - Questions about lathe chucks.
    By tahustvedt in forum DIY CNC Router Table Machines
    Last Post: 03-06-2008, 07:25 PM
  3. 4th Axis addition - V2XT
    By NC Cams in forum Bridgeport / Hardinge Mills
    Last Post: 09-26-2007, 01:01 AM
  4. New addition to the shop
    By ZipSnipe in forum Uncategorised MetalWorking Machines
    Last Post: 06-06-2006, 01:37 AM
  5. EMC Light addition
    By YZ426Tony in forum Fadal
    Last Post: 01-21-2006, 03:39 AM
