586,525 active members*
3,518 visitors online*
IndustryArena Forum > Community Club House > Need help with Routing plastic
Results 1 to 7 of 7
    Oct 2008
    6
    Hello,
    This is my first post so please excuse me if I'm in the wrong forum but I didn't see a topic for plastic.
    I am routing .5" HDPE Plastic that happens to need 15 holes per part x 19 parts per sheet. The hole drilling is taking about 30 mins. and every single hole drilled is causing plastic to ball up (see attached photo) on the single flute .25 flat endmill. I would like to find a way to manually drill the holes using a jig or multi-collet drill because I think it would be faster, in the meantime I'm stuck doing it this way.
    My machine is set up to run at 200ipm @ 14,000rpm.
    .25 single flute (spiral upcut) onsrude.
    the hole is .3125 in dia.
    Any advice on things to try to keep the plastic from spinning up on the bit?
    Thanks for taking your time to read/respond!
    Feb 2006
    210
    try dish detergent as a lube
    In the words of the Toolman--If you didn't make it yourself, it's not really yours!
    Remember- done beats perfect every time!!
    Oct 2008
    6
    I've tried everything else... wd40, Pam, oil and air are the ones to come to mind. I will try dish detergent....any particular brand?
    I know I'm dulling tools by knocking it off with scrap plastic - it's very annoying!
    Thanks for the tip!
    Oct 2006
    100
    we use compressed air when machining plastic, comes through a regulator and manifold attached to the cnc router and has a locline flex hose to put it where you need. Should solve your problem.
    Hi, just a suggestion but I'd try a faster plunge feedrate and use a peck drilling op first using you 2flute before running your nornal mill cycle to open dia. of holes.
    (faster feed rates can help reduce heat build up when tool is touching plastic)
    Good luck
    bobby
    Dec 2006
    406
    Try using a .3125 two flute instead of a single flute. Also try a chipbreaking bit to keep the chips that are formed small enough not to rap the tool. Try 10,000- 15,000 rpm with a .007-.012 chip load to determine feed. Judleroy
    Jul 2007
    1602
    Try slowing the cutter down a bit maybe 5-7000 rpm.
  1. New to CNC Routing need some help ....
    By Beardown in forum DIY CNC Router Table Machines
    Last Post: 04-17-2019, 07:17 PM
  2. Help Routing MDF?
    By lgroulx200 in forum DIY CNC Router Table Machines
    Last Post: 09-18-2008, 01:09 AM
  3. New to cnc routing
    By Duster360 in forum Commercial CNC Wood Routers
    Last Post: 08-15-2008, 08:07 PM
  4. Plastic routing (or suggestions)
    By depewke-cnc in forum Want To Buy...Need help!
    Last Post: 08-07-2008, 04:34 AM
  5. Q on CNC PCB Routing
    By soundmotor in forum DIY CNC Router Table Machines
    Last Post: 04-27-2006, 12:16 PM
