After reading many treads I thought I would start a new tread directly aimed and finding out what modifications and enhancements people have made to their X3 and X4 machines.
I think we would all agree that for the price we paid for a Chinese machine is not too bad, but there are a lot of small things that could be done to improve the machines. Many of these mods can be done ourselves with surprising results, in time hopefully Syil will pick up some of the ideas and implement them themselves in latter releases.
I would encourage you all not to make this a slanging match at Syil, but use it as an opportunity to share mods and fixes with other Syil owners.
Myself I have
Replaces all the grub screws for adjusting the play in the X and Y axis with quality screws total cost about $5 austrailian. I can now actually adjust it so there is no noticeable side play in either.
Fitted a switch to the 4th Axis so I can home it. Cost about $10.
Built magnetic splash guards so the coolant does not spay everywhere
Added a filter to the drain so none of the metal off cuts make it back around to clog up the coolant jets
Built a touch plate that sets the tool length offset each time you change cutters
