586,075 active members*
4,125 visitors online*
    Feb 2007
    505
    Cool (abnormality) cv vs exact stop
    My home made router is running mach3 with xylotex 425, and I am using bob-cad to produce the code. Recently I had tried to increased my working speed by re-tunning my motors from 20 in-min to 30.
    When I created a test file with the new feedrate and tested it my motor resonated and seem to miss step , after investigation I had to set my cv rate on the setting page to 30 , now my motors seem better but I am still getting the yellow led list of abnormality (C.V. vs exact stop ) Is there another setting that I dont know about?
    The Abnormal Condition LED is not an error condition. It just means that you have a setting set different than "normal".
    Feb 2007
    505
    Cool
    Iam receiving a ( cv vs exact stop ) message I would think there is a conflict in the setting somewhere , No?
    Or does it mean not normal compare to default settings?
    Quote Originally Posted by Claude Boudreau View Post
    Yes, but not necessarily default. You can double click it I think to set what's "normal".
  1. EMC2 E-stop parallel port pinout and E-stop loop
    By GreenLead in forum LinuxCNC (formerly EMC2)
    Last Post: 08-03-2010, 06:05 PM
  2. Anyone know where to get this exact type of servo motor?
    By SCCoupe in forum DIY CNC Router Table Machines
    Last Post: 03-18-2006, 04:58 AM
  3. How to make the frame exact
    By signIT in forum DIY CNC Router Table Machines
    Last Post: 05-28-2004, 08:04 PM
