Gday folks!
I'm planning to build my own CNC routertable right now. Because I'm a real woodworker and not een electronerd it's quite hard to understand all the things about the electrics!
But still going strong, this forum helps a lot. Allready read a lot of interesting things and seen some amazing pics!
My specs:
Table size: app. 70x60 cm. Due to the size I want the table to be static
I'm thinking about the HobbyCNC plan or something like that.
Material: Wood, Acrylic glass, MDF. I want to use standard 6mm bits or smaller to cut 18mm thick material or thinner
Router: I'm planning to use my Metabo router (710Watt 6mm shaft) and/or a standard Dremel. But I guess for the bigger parts the dremel is to light.
Software: want to use software which is easy and makes it possible to translate Coreldraw pics to.
Motors: haven't got a clue
Hardware: dito
Gliders: dito
money: <500$
In all I think it must be pretty heavy duty.
I'm watching Ebay for parts and read a lot of sites and forumannouncements allready but I can't find good advise about the amount of torgue (Ncm / Oz/in) needed to make the machine work.
Can someone give me some good advise and/or share his experience building a machine like mine?
NB.
I'm planning to come to the US in april 05 (SF.area CA.) Thanks to Bush the Dollas is incredibly cheap at the moment. Being Dutch I want to order my motors and hardware in the US and pick them up by then..
