586,058 active members*
4,100 visitors online*
Thread: g42 trouble
Results 1 to 7 of 7
    Dec 2008
    26
    g42 trouble
    hey guys,
    i just started learning cnc programming and i'm having trouble using the g42. i tried programming the g42 in the beginning of the program and cancelling it on a depart move at the end, but my parts weren't coming out right. i also tried calling it and canceling it whenever i needed it for a radius, but that didn't work either.
    Does the G42 work when you are doing a radius on a G1 (ex: g1 z-3. r.03)? Thats what i've been trying and i'm thinking maybe it only works with a g3?
    Thanks for the help,
    Manoj
    How do you do a radius on a G1?? What control are you using?
    Dec 2008
    26
    i have a haas machine... the radius i put in after the g1 lets me do a corner rounding.. so if i'm going from the z axis to the x-axis i can put a radius in between really easily... same for chamfering...
    Jul 2005
    12177
    On a lathe when you use Tool Nose Radius compensation you also have to specify the Tool Tip Orientation by entering a Tip Code. Your manual describes this or you will find it on page 68 of this pdf file from the Haas website;
    http://www.haascnc.com/customer_serv...he/96-8700.pdf
    Dec 2008
    26
    i did that and also specified the tool radius is there anything else i could have missed? i tried to follow it step by step from the manual...
    thanks,
    manoj
    Dec 2008
    26
    actually geof,
    i looked through the manual you put up and it seems a little more detailed than the one i was using. i'll give it another shot tomorrow. i'll let you know what happens.
    thanks,
    manoj
    Jul 2005
    12177
    Attach a file with a complete program and I will run it through my Simulator and TL2 and see if I can find what is not working (tomorrow).
  1. Trouble
    By extreme in forum DIY CNC Router Table Machines
    Last Post: 07-11-2010, 10:14 PM
  2. c6 trouble
    By wilko1 in forum Syil Products
    Last Post: 06-28-2008, 11:20 PM
  3. 100 in/min X, Y, Z with IH CNC Kit. Any Trouble??
    By haysys in forum Charter Oak Automation Support Forum
    Last Post: 02-02-2007, 03:24 AM
  4. More PIC trouble
    By robe_uk in forum CNC Machine Related Electronics
    Last Post: 10-10-2006, 09:13 PM
  5. having trouble getting this to cut right
    By MIKENLN in forum BobCad-Cam
    Last Post: 04-19-2005, 08:24 AM
