586,103 active members*
3,788 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > What do you think of this machine?
Results 1 to 9 of 9
    Nov 2006
    104
    I was looking around and I saw this picture
    http://www.stepperworld.com/Gallery/...ure4%20053.jpg
    What do you think about the forces on a simple build like this?
    Oct 2005
    69
    Quote Originally Posted by fahque99 View Post
    I guess, that milling some soft materials and make some "artistic" parts, that dont need to be accurate, it is good, but anything more from that...milling hard materialls and wanting some tolerances, I think that general layout of this machine doesnt allow.
    Long arm from the tool to supports (rails and bearings) can lead to deformations in elastic area and generate some deviaton of actual tool path against the theoretical path.
    But this is just my opinion considering this photo you give us in your post.
    Mitja
    Dec 2006
    8
    Cool Machine in picture
    Yes; I agree. The arm needs to extend to cover a reasonable (small) area, but the support is then quite far from the point of support at the bearings, and that would suggest problems of accuracy when machining anything other than very soft materials like wax or soft plastic sheet.
    The machine has a neat clamp for the Dremel, though.
    Aug 2008
    8
    It looks a great setup - Apart from worrying about the obvious, like distance, I usually find looking at the actual tool makes a huge difference. ie where I though I would get too much vibration, by changing to a different type of tool the piece cuts nicely - even in very hard materials.
    ie dont just look at standard milling cutters
    www.thecncfactory.com
    Jan 2006
    13
    It is a good LOOKING design and would look great running. I agree with the criticism of the long arm. Any amount that you could increase the length of both slides where the X and Y axis connect would help some. This may be easier said than done. Stay on light work, harness up some of that wiring, and paint the parts that appear to be wood grey and the picture makes me want to build one too.
    TH
    Mar 2006
    9
    This is plasma cutting so the forces wouldn't be those of conventional milling. I don't know much about it but guess that any forces involved would be similar in idea to a rocket but much much smaller and probably insignificant. More than the cutting forces, it would seem the nature of the method iteslf - you're basically melting away metal - wouldn't give you the accuracy of conventional milling. As a previous poster mentioned this seems more suited for artistic work or cutting metal sheets for welding.
    Nov 2008
    Wink My opinion
    It looks like one of my first designs, and i can assure that it´s not stiff enough to mill hard materials with good tolerances. I made some fem tests over a similar design and it is not very stiff.
    Oct 2005
    69
    Quote Originally Posted by igwood View Post
    This is plasma cutting ...
    Do we look at the same machine photo?
    Nov 2006
    114
    If this was used as a rig for a plasma cutter as igwood claims, then I would say yes as long as all the ways were coverd to keep out the dirt and I would add some kind of traveling counter balance on the Y(maybe a gas ram with a progressive leverage linkage)
    To use this for any kind of stock removel tool would probably be very disapionting unless the ways were much more substantial than what we see here.
    It is a clever design though, and nice execution too.
    I think I have seen this kind of set-up in medical labs titrating chemicals into trays of test tubes...
  1. saleCNC laser engraving machine and CNC woodworking machine
    By zhangrui1588 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-08-2011, 09:54 PM
  2. sell CNC Woodworking Machine,CNC Advertising Machine
    By zhangrui1588 in forum News Announcements
    Last Post: 05-30-2008, 02:43 PM
  3. Deep Groove Taig machine would it be a good starter machine
    By Fritzie15 in forum Taig Mills / Lathes
    Last Post: 09-21-2007, 03:37 AM
  4. Mach 2 on old machine = great machine
    By foamcutter in forum Machines running Mach Software
    Last Post: 12-16-2005, 07:11 PM
