This is the base that I am planning and want some opinions on the construction. It is made of 2" square tubing, in four sections, each section is welded together then the brown sections are bolted to the gray sections.
I am hoping that by adding a horizontal piece about 6” down it will add enough rigidity, what do you think?
Typically I see a lot of constructions using diagonal bracing forming triangles which makes for a very rigid form. However diagonal bracing makes it very difficult to utilize any of the inner spaces for drawers and storage.
Comments and suggestion appreciated.
