586,072 active members*
4,683 visitors online*
Page 1 of 2 12
Results 1 to 20 of 32
    Nov 2004
    56
    converting to dfx
    Does anyone know how to or have a program to convert jpeg or bmp to dfx...attached is a jpg file that I would like to engrave......Thanks :cheers:
    6855
    Apr 2004
    439
    not sure if this is what you want or not but her you go :P Adobe Streamline 4.0
    Attached Files Attached Files
    24221
    Not a self-portrait I hope
    Al
    Albert E.
    this wwent thru signlab
    Nov 2004
    56
    Thanks ......
    Thanks alot guys....... :cheers:
    270
    This one was done with RasterFratz. Smoothness setting of 3.
    Fred Smith - IMService
    http://www.cadcamcadcam.com
    Fred, can Rasterfratz create .dxf's that AutoCAD can open? ACAD 2002 couldn't open that one.
    270
    Gerry, do what you would do to open a DXF saved with Autocad rel 10,11,12,13,14, or 2000, but not in 2002. Maybe look for a file import or merge rather than a direct file open, which may be set to open DXF files created ONLY with rel 2002/2004/2005, etc.
    Nov 2004
    56
    Thank you
    Thank you Fred......That one is really nice...simulated it in Mach 2 and looks like what I was looking for....Thanks Again..... :cheers:
    I will have to check out that software
    Quote Originally Posted by imserv
    I get an error message saying table flags missing on line 38 - invalid or incomplete .dxf
    AutoCAD doesn't care what version it's opening. There are no options. You open a .dxf with the open command, and select .dxf in the file type box. Any version should open this way. I guess AutoCAD is more picky than most because it's their format. Does Rasterfratz have .dxf version options when saving or exporting?
    Sep 2003
    18
    I could not get it to work either, the second file that is. Has anyone tried wintopo ?
    Steven
    The one from Fred? imserv?
    270
    Quote Originally Posted by ger21
    Apparently it does care whose version. ;-)
    There are no DXF versioning options in Rasterfratz. I try to keep it at the current VectorCam level, but it may be out of synch now.
    Try the attached file from Vector 10 and see if it will open. If it does, I will update the DXF template in Rasterfratz.
    http://www.cadcamcadcam.com/hobby
    Yes, Fred, the Vector version opens fine. I tried the Rasterfratz one on my home computer and get the exact same error I got at work.
    just wondering if anyone had a problem opening the file
    i posted
    Nov 2004
    56
    I tried it and could not open it.....
    Jan 2004
    190
    I opened it in bobcad and Cadstd with no problems
    thanks Kenneth
    www.lambertsrc.com
    Apr 2004
    439
    opened in solidworks fine too :P
    Nov 2004
    56
    I tried to import into Cad Std and it would not open it....Hmm...
    The one that spezzaferro did is the only one I can't open...
Page 1 of 2 12
  1. DFX is not imported correctly...
    By ihkim in forum Uncategorised CAM Discussion
    Last Post: 01-07-2010, 06:57 PM
  2. converting o-t to oi-t params
    By omniturn5 in forum Uncategorised MetalWorking Machines
    Last Post: 03-29-2005, 11:10 PM
  3. Converting jpeg. to dfx.file
    By tozlakes in forum Waterjet General Topics
    Last Post: 12-23-2004, 10:40 PM
  4. Converting a mini from geared to belt driven
    By cncadmin in forum Benchtop Machines
    Last Post: 11-04-2004, 05:15 PM
  5. Newphie converting a J model
    By flightride in forum Bridgeport / Hardinge Mills
    Last Post: 06-06-2004, 03:27 PM
