586,075 active members*
4,019 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > GA4566-1 servo drive REPAIR or REPLACE
    Sep 2008
    3
    We have a FADAL 4020 with a bad servo drive card (older GA4566-1 short card). We sent it to a repair facility that claimed to repair these boards, but when they found out that some of the output transistors (GTK45595) were dead, they said they couldn't repair it. I have seen some other repair places on the web that claim to be able to repair these:
    A: acsindustrial.com
    B: nyco-systems.com
    C: plccenter.com
    D: servo-repair.com
    E: perhaps kmac-parts.com
    F: perhaps teknic.com
    Can they only repair these if ALL the transistors still work?
    Also fadalcnc.com has a "DC-UNIVERSAL AFTERMARKET" amp card "AMP-001A" for which they don't provide much in the way of technical specs, but it might work. Also ajaxcnc.com has what looks like a good DC servo drive, though the current might be a little lite, and it would need the feedback system changed to their own encoder.
    What do you think would be the best way to get the 4020 back up and reliably making parts?
    As an aside, it appears GlenTek has made a great effort to keep these transistors parameters a secret There must be somebody who knows servo boards well enough to suggest a good replacement for these devices. ON semiconductor makes some pretty beefy TO-3s. I suspect there may need to be some modifications to keep more modern fast transistors from oscilating in the older boards.
    Thanks for any help you can provide. Trying to get an older servo drive card repaired or replaced seems to be peppered with pitfalls for those who don't know better.
    PS: I suspect it's got a -0 controller; 1040-0, 1020-0, 1030-0, and 4 by 1010-1 plus a 1420-1 and one other card with lots of memory chips where the other cards have part numbers.
    Re: GA4566-1 servo drive REPAIR or REPLACE
    Quote Originally Posted by cogoman View Post
    B: nyco-systems.com
    C: plccenter.com
    D: servo-repair.com
    This would be a replacement for the GTX45595 ( MJ10023 NPN 40A 400V TO-3)
    Sep 2004
    148
    Why not send it to Glentek for repair?
    Quote Originally Posted by triumph406 View Post
    I open the TO-3 case and check the die. the MJ10023 NPN has the same electrical configuration as the GTK45595. both are made by motorola.
    this is the Description of the MJ10023.
    Collector?Emitter Voltage, VCEV ........ 600V
    Collector?Emitter Voltage, VCEO(sus) 400V
    Emitter?Base Voltage, VEBO ..............8V
    Collector Current, IC
    Continuous ..........................................40A
    Peak .................................................. ..80A
    Base Current, IB ..................................20A
    Total Power Dissipation, PD
    TC = +25?C ........................................250W
    Derate Above 25?C 1.43W/ ............... ?C
    TC = +100?C ......................................143W
    Operating Junction Temperature Range, TJ ........ ?65? to +200?C
    Storage Temperature Range, Tstg ....................... ?65? to +200?C
    Thermal Resistance, Junction?to?Case, RthJC .. 0.7?C/W
    hope this helps.
  1. Mitsubishi Servo Drive / Repair / Replacement
    By jdingus in forum Want To Buy...Need help!
    Last Post: 09-21-2012, 03:54 PM
  2. Servo drive repair leads to electrical fire
    By roadking in forum Fanuc
    Last Post: 05-28-2009, 06:25 PM
  3. Dynapath 10 replace servo drive & power supply??
    By ken fedirko in forum DNC Problems and Solutions
    Last Post: 01-13-2008, 12:30 AM
  4. Table Drive Motor Repair/Replace?
    By awright in forum Bridgeport / Hardinge Mills
    Last Post: 11-29-2007, 08:39 AM
  5. repair or replace?
    By hollyfeneht in forum Benchtop Machines
    Last Post: 06-04-2007, 11:27 PM
