586,075 active members*
3,798 visitors online*
    May 2008
    8
    Question HPGL & CadKey 19
    I like to use Front Pannel Designer for the occasional quick project. Its one of those on-line program set-ups that they provide the software; you make your design/pattern; it instantly quotes you... Click send and in a few days its at your door.
    Here is my dilemma. I Use CadKey most of the time and I want to export/convert some of my .prt files to a HPGL file (so i can import to Front Pannel Designer). Does anybody know of a cheep(read freeware) PRT/DXF/STEP to HPGL converter? Or mabe a better solution?
    Any advice or help would be greatly appreciated.
    Apr 2008
    12
    Can you set up an HPGL printer and do a print to file to get the HPGL output. They may want a specific printer driver to use for the import, but HPGL is really just pen moves.
    www.cncprogramdeveloper.com
  1. HPGL engraver.
    By WilDun in forum Machines running Mach Software
    Last Post: 10-26-2009, 05:11 AM
  2. Cadkey
    By mmachining in forum Uncategorised CAM Discussion
    Last Post: 05-01-2006, 10:11 PM
  3. cadkey
    By drill in forum Uncategorised CAM Discussion
    Last Post: 01-28-2006, 07:39 PM
  4. HPGL help me!
    By vacpress in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 01-09-2006, 10:49 AM
  5. HPGL or PLT Creator
    By tburkard in forum Uncategorised CAM Discussion
    Last Post: 11-28-2005, 10:15 PM
