586,112 active members*
3,169 visitors online*
    Jan 2009
    4
    Special Parameters Settings
    Dear CNC zone partners,
    I'm looking for the special settings parameter of a Fanuc controller series OT model D. Somebody could help me with this problem? i had to clear the ram because the machine is disable to make any operation. Thanks
    24221
    Do you mean the 900 option parameters or the general setup parameters, Both are unique to the machine as set by the MTB, you will either have to contact the MTB or post the make model if you are missing the parameters, in the hope someone has the same machine.
    Al.
    Albert E.
    Jan 2009
    4
    Thanks Al,
    Yes, i'm looking for the 900's parameters. I have a copy of the data sheet where the special parameters are, however much of them are not visible. These are some datas about the controller:
    Mark: Daewo Puma 8HC
    Model: A02B-0098-B511
    Serial Number: 0060550
    Regards
    Mar 2006
    33
    option parameters
    the "setting" page key and the "parameter" key take you to different places
    Nov 2008
    37
    Smile
    Hello everyone, FYI maybe this link could be useful http://cncfanuc.blogspot.com
  1. Please list your most used settings and parameters
    By 1ctoolfool in forum Haas Mills
    Last Post: 02-27-2013, 03:49 AM
  2. Mach3 CV settings vs. G-100 Plugin CV settings
    By Bfarn in forum Machines running Mach Software
    Last Post: 12-17-2008, 05:45 PM
  3. parameters,settings
    By Michael82 in forum Haas Lathes
    Last Post: 11-19-2007, 04:02 PM
  4. Special CNC lathe
    By fiki in forum Uncategorised MetalWorking Machines
    Last Post: 08-23-2007, 05:29 PM
  5. Need 'special' PSU...
    By WilliamD in forum CNC Machine Related Electronics
    Last Post: 09-26-2006, 02:41 AM
