Any chance of a reamer handling .025"? Of course this is only .0125" on each side. I know that is a big cut, I have always went with no more than .010". Any opinions? Oh ya, cutting a soft casting. Thanks.
Shawn
The more you cut, the more likely the reamer will cut oversize, and chips may score the hole. If you "peck-ream" with complete retractions, you may be able to prevent scoring the hole. I like your first impression of .010. That's comfortable, if the reamer is in the 1/4" range on up.
Thanks, that is what I figured, maybe I can try to peck and see.
Shawn
Also depends on the size of the reamer. Get up in the 1.250-1.500 range and .025 stock removal is the norm.
