586,112 active members*
3,065 visitors online*
Results 1 to 8 of 8
    Feb 2007
    91
    milling deep thin slot
    I need to mill a slot in aluminum that is 1.5" deep and 1/8" wide. This slot is about 5" long. What do you guys suggest as the best way to do this?
    Thanks in advance
    Feb 2007
    464
    I'd use a slot cutter.
    But it depends on if the slot is open or not,straigh or curved,tolerances,if there's enough room for it.
    Stefan Vendin
    Feb 2007
    91
    When you say slot cutter I assume you are talking about a slotting/slitting saw? If this is the case do you know of a good source. The only one I can find is .128" thick and 2-3/4" in diameter. I really need atleast a 3" in diameter cutter and that would depend on the size of the arbor. Then what do you do at the ends of the cut where they are curved instead of the 1.5" overall depth?
    Jun 2008
    1511
    What kind of material are you milling into? I would do as Mitsui had said. Use a disk cutter. I don't know if they make inserted disk cutters in this width. I have always used a carbide saw 3" in diameter. Depending on what you are cutting climb milling is usually a must.
    We also had to remove the radius at the start and end of each cut. Most of our slots were only .042" wide and and about .25" deep so we used a spindle speeder to get the RPM needed to mill out the radius with and endmill. You pick away at it like a staircase starting at the top.
    Stevo
    Nov 2004
    260
    If you are doing just one it would be fastest to just mill the slot.
    preferably from both sides so you only need to go down 0.75".
    High spindle RPM and a Airmist coolant to blow the chips out.
    Take no more then 0.05" depth each pass and also feed it back and forth.
    SHould be easy enough.
    Feb 2007
    464
    Quote Originally Posted by dlenardu View Post
    Try this.
    http://ecat.secotools.com/
    Search for a disc cutter named R335.10
    At the ends you can do a simple contour with a 3/32 endmill ,working your way down to depth.
    Stefan Vendin
    Oct 2003
    192
    Slitting saws or cold saws work best,...but tooth form should be ground for alum. for best results.
    For alum. you need coarse teeth.
    On your .128" blade....grind down side to about .123"...it will cut oversize a bit.
    Konrad
    Mar 2008
    443
    For a slot that deep it seems to me you need a slotting cutter at least 4" in diameter, but even with that you'd need to have an arbor of less than 1" diameter. Not likely.
    My Valenite catalog shows you'd need a 6" outside diameter one to get that depth of cut. Their V350 A 12 60 D14 would do the trick. It's got a 1.5" hole, so you need an arbor that size.
    The 14 inserts you should get for it would be VSG 3.10 N 30-SC. Those are .123" wide, but the likely overcut would make your slot just about .125". If they run tight you could try the VSG 3.18 N 30-PG. Those are .125" wide, exactly.
  1. milling thin wall brass tubing
    By jackie_burton@m in forum Material Machining Solutions
    Last Post: 09-29-2008, 09:46 PM
  2. Helical milling a slot
    By kevinheez in forum Surfcam
    Last Post: 05-02-2008, 01:14 PM
  3. Simple slot milling problem
    By jwknow in forum Mastercam
    Last Post: 01-23-2008, 12:03 AM
  4. milling deep pocket
    By barnesy in forum MetalWork Discussion
    Last Post: 09-16-2006, 11:00 AM
  5. Replies: 5
    Last Post: 05-29-2005, 03:17 AM
