586,106 active members*
2,992 visitors online*
    Jan 2007
    6
    Red face Format 4 from Felder
    hy
    My first language its Croatia-n and please sorry for bad english !!!
    I working on Felder Format 4 Machining Center - this machine using TPA/ALBATROS/EDICAD
    This is example of program :
    TPA\ALBATROS\EDICAD\01.00:75:r0w0
    ::SIDE=1;
    ::UNm DL=1931 DH=245 DS=38
    OFFS{
    #0=0.0|0
    #1=0.0|0
    #2=0.0|0
    #3=0|0
    #4=0|0
    #5=0|0
    #6=0|0
    #7=0|0
    }OFFS
    VARV{
    #0=0.0|0
    #1=0.0|0
    #2=0.0|0
    #3=0.0|0
    #4=0.0|0
    #5=0.0|0
    #6=0.0|0
    #7=0.0|0
    }VARV
    VAR{
    }VAR
    SPEC{
    ::0
    ::0
    ::0
    ::0
    ::0
    ::0
    ::0
    ::0
    ::0
    ::0
    ::0
    ::0
    ::0
    ::0
    ::0
    ::0
    ::0
    ::0
    ::0
    ::0
    }SPEC
    OPTI{
    ::0
    ::0;0;0;0;0;0;
    ::0;0;0;0;0;0;
    ::0;0;0;0;0;0;
    ::0;0;0;0;0;0;
    ::0;0;0;0;0;0;
    ::0;0;0;0;0;0;
    ::0;0;0;0;0;0;0;
    ::0;0;0;0;0;0;0;
    ::0;0;0;0;0;0;0;
    ::0;0;0;0;0;0;0;
    ::0;0;0;0;0;0;0;
    ::0;0;0;0;0;0;0;
    }OPTI
    LINK{
    }LINK
    PREV{
    }PREV
    SIDE#1{
    W#81{ ::WTp WS=3 #1=27.5+20 #2=160 #3=-15 #8015=0 #1002=8 #201=1 #1001=1 }W
    W#81{ ::WTp WS=4 #1=l-27.5-20 #2=160 #3=-15 #8015=0 #1002=8 #201=1 #1001=1 }W
    W#89{ ::WTs WS=1 W$=~drckerloch #8015=0 #1=110 #2=50 #3=-2.5 #8101=0 #8096=0 #201=1 #205=1002 #40=0 #8136=0 #8135=0 #9521=0 }W
    W#2201{ ::WTl #8015=0 #1=l-110 }W
    W#2101{ ::WTa #8015=1 #1=30 #2=30 #31=30 #34=0 }W
    W#2201{ ::WTl #8015=0 #2=h-80 }W
    W#2101{ ::WTa #8015=1 #1=-30 #2=30 #32=30 #34=0 }W
    W#2201{ ::WTl #8015=0 #1=110 #2=h-50 }W
    W#2101{ ::WTa #8015=1 #1=-30 #2=-30 #31=-30 #34=0 }W
    W#2201{ ::WTl #8015=0 #2=80 }W
    W#2101{ ::WTa #8015=1 #1=30 #2=-30 #32=-30 #34=0 }W
    W#2201{ ::WTl #8015=1 #1=30 }W
    W#89{ ::WTs WS=2 W$=~kontraprofil vrata 1 #8015=0 #1=-50 #2=0 #3=-7.5 #8101=0 #8096=0 #201=1 #205=2001 #40=2 #8136=0 #8135=0 #9521=0 }W
    W#2129{ ::WTa #8015=0 #8026=l #8027=0 #3=-7.5 #8029=l #8030=h #8017=2 }W
    W#2129{ ::WTa #8015=0 #8026=l #8027=h #3=-7.5 #8029=0 #8030=h #8017=2 }W
    W#2129{ ::WTa #8015=0 #8026=0 #8027=h #3=-7.5 #8029=0 #8030=0 #8017=2 }W
    W#2129{ ::WTa #8015=0 #8026=0 #8027=0 #3=-7.5 #8029=30 #8030=0 #8017=2 }W
    W#2201{ ::WTl #8015=0 #1=30 #2=0 #3=-7.5 }W
    W#89{ ::WTs WS=18 #1=525.7142 #2=70 #3=-2.5 #201=1 #203=1 #205=1002 }W
    W#2201{ ::WTl #1=500 #2=70 }W
    W#2201{ ::WTl #1=500 #2=75.7142 }W
    W#2101{ ::WTa #1=501.2408 #2=75.8087 #31=-19.9806 #32=270.7838 #34=1 }W
    W#2101{ ::WTa #1=502.7669 #2=75.9312 #31=-39.744 #32=504.5187 #34=1 }W
    W#2101{ ::WTa #1=505.2455 #2=76.1383 #31=-80.0698 #32=973.0091 #34=1 }W
    W#2101{ ::WTa #1=507.1118 #2=76.3345 #31=-4.0975 #32=47.9496 #34=1 }W
    W#2101{ ::WTa #1=508.6125 #2=76.575 #31=-3.2885 #32=25.3322 #34=1 }W
    W#2101{ ::WTa #1=510.0446 #2=76.9642 #31=-2.0747 #32=10.4618 #34=1 }W
    W#2101{ ::WTa #1=511.2734 #2=77.5602 #31=-3.8472 #32=9.4969 #34=1 }W
    W#2101{ ::WTa #1=512.2812 #2=78.2767 #31=-3.892 #32=6.5413 #34=1 }W
    W#2101{ ::WTa #1=513.2812 #2=79.4196 #31=-4.2503 #32=4.728 #34=1 }W
    W#2101{ ::WTa #1=513.7935 #2=80.4656 #31=-5.0445 #32=3.119 #34=1 }W
    W#2101{ ::WTa #1=514.125 #2=81.7285 #31=-7.883 #32=2.7439 #34=1 }W
    W#2101{ ::WTa #1=514.2857 #2=83.75 #31=-13.8967 #32=2.1219 #34=1 }W
    W#2201{ ::WTl #1=514.2857 #2=155.0446 }W
    W#2101{ ::WTa #1=514.2194 #2=156.4435 #31=-15.8188 #32=-0.0486 #34=1 }W
    W#2101{ ::WTa #1=514.0205 #2=157.6937 #31=-11.625 #32=-1.2083 #34=1 }W
    Now i wish to work some engraving on this machine (2.5 D )
    I have VCarve,PhotoCarve ..... and this is beautiful program for this stuff
    but i cant make this type of file for this machine !!! extension of this file is
    *.cnc
    Can anybody help my and tell my for any postprocesor who can convert jpeg or bmp..... in this code for Format 4 ????????
    Or postprocesor who can make this code from dxf with Z coordina....... in this code !!!
    SORRY SORRY for bad English but i hope do you understand what is my problem !!!
    Hi Senna 666
    I can help you to generate this Format; also i can convert a jpeg in CAD Format and generate the NC Lines !
    Please send me your Email and i will send you a example with engraving your name or some example that you want!
    see you
    Router
    Jul 2014
    39
    Re: Format 4 from Felder
    Hi
    You can use my way.
    I wrote a postprocessor for NX and I make my g-codes inside it with format4 post.
    I can use rough machining and engraving.
    It work nice for me.
  1. dxf format
    By blackrat in forum Jewelry Design Software
    Last Post: 02-25-2008, 07:07 PM
  2. dwg to IGES or pro-e format?
    By XXF in forum Autodesk
    Last Post: 04-24-2006, 09:08 AM
  3. Format 1
    By MegaMoog in forum Fadal
    Last Post: 04-07-2006, 12:08 AM
  4. Using CRC in Format 2
    By Mese in forum Fadal
    Last Post: 03-29-2006, 02:37 AM
  5. fadal format 1
    By bthomps5 in forum Fadal
    Last Post: 03-13-2005, 06:38 PM
