586,106 active members*
2,987 visitors online*
Thread: Import DXF
    Sep 2006
    5
    Import DXF
    I have an older version of Bobcad (v.15). I'm tying to export a dxf from CorelDraw, but when I open the file in Bobcad, nothing appears, What am I doing wrong? Thanks.
    Dec 2008
    4548
    Quote Originally Posted by Nat Wheatley View Post
    I dont have V15 to follow along but something that comes to mind is What version of DXF was out when V15 was around and what version export is Corel using??? Is there an option in the Corel export to set a version of DXF on export??
    Burr
    Apr 2007
    243
    Make sure the color of your DXF file is not the same as the back round color on your BobCAD.
    Also sometimes the dxf's can come in with the geometry blanked out. So try un blanking and see if that helps.
    Or sometimes you just need to hit view all, because the part came in off Zero and you can't see it in the default view of BobCAD.
    If it's none of those than you have to check what type of geometry you are trying to bring in from corel.
    Breaking or exploding helps to break the geometry down the line and arcs that older systems read more easily .
    You also might want to just save the part geometry you want, no dimensions and boards and other stuff that might not be supported.
    Dec 2008
    4548
    I think in Corel you have to select the objects your expoting also. Try select all in corel before you export.
    Mar 2008
    163
    try exporting from corel as a DWG....you may have older translation protocals than corel with V15
  1. import
    By Pecker in forum Surfcam
    Last Post: 07-17-2008, 07:49 PM
  2. DXF Import
    By Martin Long in forum Syil Products
    Last Post: 07-14-2008, 04:38 AM
  3. import dwg?
    By dewme5 in forum EdgeCam
    Last Post: 01-10-2008, 12:34 AM
  4. import DXF
    By qmas99 in forum FeatureCAM CAD/CAM
    Last Post: 07-19-2006, 01:08 PM
  5. DXF Import
    By Todd Price in forum Rhino 3D
    Last Post: 06-07-2004, 06:24 PM
