586,082 active members*
3,563 visitors online*
    May 2007
    24
    Trial running Mach3 with printer connected
    Hello group,
    If I trial run Mach3 with my printer connecter to the parallel port, can I do any damage?
    Pat
    Mar 2007
    11
    I dont know, but if your printer is under warrenty then just take it back if it damages it lol. I dont think any damage can be done to the pc becuase it is just software, but to be honest I dont know
    Feb 2007
    4553
    Smile
    Pat,
    Make Mach3 the default printer first.
    That way you wont end up sending Mach3 commands to your printer.
    The printer will not like what Mach3 tells it!
    Also power off the printer before running Mach3.
    Welcome to the Zone,
    Jeff...
    May 2007
    24
    Thank you both for the replys!
    Maybe I should just unplug the parallel cable to be on the safe side.
    Pat
    I haven't had a printer with a parallel port in a long time, but I do have a dongle attached to my parallel port, and Mach hasn't hurt it at all in the few years I've been playing around with it.
  1. Running Mach3 on a little Acer One
    By felixthecat728 in forum Machines running Mach Software
    Last Post: 01-09-2010, 05:57 PM
  2. Running Mach3 with only X&Y Axis
    By kae in forum Mach Mill
    Last Post: 12-31-2008, 11:21 PM
  3. running Printer drivers and steppers with Mach3?
    By mwood3 in forum Mach Software (ArtSoft software)
    Last Post: 08-09-2008, 05:59 AM
  4. running mach3
    By woodman08 in forum Machines running Mach Software
    Last Post: 02-26-2008, 05:21 PM
  5. DPRNT- ignore if no printer connected
    By pieface in forum Fanuc
    Last Post: 11-07-2007, 02:43 PM
