Coolant Pan
Finished my flood coolant pan yesterday and have it all installed now. Will probably order the Enco coolant tank and pump unless something better pops up. I have a big steel job coming in a few weeks and wanted to be ready for it. The pan is 14 gauge sheet metal, I had a local fabrication shop shear and brake the major pieces then I brought it all home and finished cutting and welding it up. I basically copied the diminsions of the basic stand pan except mine is about 1 inch deeper, I wanted steeper angles on the side to ensure rapid coolant return.
BlueFin CNC LLC
Southern Oregon
