Originally Posted by
handlewanker
Hi all, encoders just tell you where you are at, they do not hold back the raging beast when it gets the bit between it's teeth.
Interpreted means, if you are climb milling you don't need the table to take off under it's (the cutter) own steam.
It's about control all the time, from A to B and back to A without the machine reforming the parts due to the tool taking control of the movement.
Hydraulic drive with incompressible oil (practically so) needs to have something to inject the oil at the start to get a movement that is significent as opposed to random.
I toyed with the idea of a drive where a piston injected a fixed amount of oil into a chamber under the action of a cam, with a chamber/piston ratio of 1:60, which means if the piston pumped 60 strokes to the chamber and it moved a table round I turn you have a hydraulic drive with no backlash and a high resolution count.........BUT....
Do that a hundred times and at the hundredth reversal you could have a couple of molecules of oil too much and so you
are out of position and the excess or short fall in the oil supply will not give accurate results....this is similar to a friction drive in all respects.
If the piston pumps as well as sucks the oil on opposite side of the piston, a closed circuit, you could get a 1:60.5 ratio which is as random as you can get.
With an encoder sensing where you are at and a very firm friction drive to give you continuous movement totally under control and without backlash.......hey , all of a sudden you have the ideal drive for all occasions so far noted.
The fly in the honey pot is the ability of the friction drive to resist not being stalled or moved by the cutter forces, one reason the toothed belt, gear, or worm drive is so positive.
The friction drive would consist of two plates off-set to each other, one spring loaded and attached to the input drive with the other attached to the output to the table, with a wheel sandwiched between the plates and transmitting the drive to the second plate......the ratio of the drive derived from the position the sandwiched wheel take on the drive and driven plates.
This method is used in an infinitely variable speed drive attached to an electric motor and has a wheel that moves the two plates relative to one another to give a variable offset, hence a variable speed, dependent on the capacity of the friction to give a torque handling capability to the drive.
It will work for all needs in the ideal 4th axis......size dictates the torque handling ability of the drive by the coefficient of the drive surface friction, but a ratio of 1:60 is not a dream, if you can get an offset to the drive and driven plates of 1:60 with regards to the plate diams and the input/output shaft alignment......encoders are just the jam in the sandwich making sense of the slip in the movement of the two plates......food for thought.
If encoders be the answer to the precise resolution sensing, then friction drive is the answer to the drive itself, having all the necessary functions for forward and revers actions without a dwell point in the action, commonly called backlash.
Now I'm off on another quest for another holy grail, and friction drive might be the answer which has been so close but overlooked by hiding in broad daylight.
From the beginning of time, friction has made possible the invention of wheel in it's many forms.
Ian.
