586,299 active members*
3,832 visitors online*
Results 1 to 1 of 1
    Mar 2008
    9
    New design, gantry or something else
    Hi
    Im starting to design a new CNC machine for steel. Im having hard time deciding wether to build a moving gantry or something else.
    CNC should be able to machine approx. 1.2m (or maybe more) x 1m x 400 mm (X Y Z). Im thinking two different approaches -moving gantry or moving table.
    I've made 2 quick sketchups and some comparison between them.
    Jyrsija1 mockup is the Moving gantry -version
    Pros:
    - Takes only little space around working area
    - Table can be built very heavy and sturdy
    Cons:
    - Might require 2 leadscrews on gantry axis
    - Moving masses pretty high on gantry axis
    - Gantry limits working piece size
    Jyrsija2 mockup is the Moving table -version
    Pros:
    - Milling head moves only on vertical axis
    - Milling head can be built very sturdy
    - One leadscrew on each axis
    - Mill head tilt axis quite easy to implement (on gantry style the gantry might be limiting the tilt, depends on the build)
    Cons:
    - Table must be built sturdy
    - Table linear guides must be very heavy to take the masses and torque
    - Takes a lot of space on sides and front
    Ill take ideas and pros/cons on designs.
    First Ill make some mockups more and then Ill start to design the real thing and if Ill have enough money then Ill build the thingy (Ive built one stationary gantry style wood machine before (actually its under development right now) so this is my 2nd design)..
  1. Design: overhead gantry
    By Gizmot in forum Uncategorised MetalWorking Machines
    Last Post: 04-01-2008, 09:33 PM
  2. Finding Engineering Design Software For Automatic Machine Design
    By hellokitty in forum Uncategorised CAM Discussion
    Last Post: 01-06-2008, 07:39 AM
  3. GANTRY Design
    By bert5604 in forum Waterjet General Topics
    Last Post: 10-01-2007, 02:30 PM
  4. Gantry design question
    By anthony in forum Mechanical Calculations/Engineering Design
    Last Post: 04-27-2005, 07:39 PM
  5. Gantry design???
    By dmgdesigns in forum DIY CNC Router Table Machines
    Last Post: 05-25-2004, 03:13 PM
