586,271 active members*
3,642 visitors online*
    Jan 2009
    Exclamation solid edge / mastercam
    Our company is looking for a cnc router software to run our new 2-1/2 axyx router. We are using Solid Edge. We are cutting plastic sheets (2d cutting only) We need a good nester and a good transfert between SE and the cam software. We have looked at 2 sofwares: Act Cut from Alma and Mastercam. We currently use Art Cam but it is almost useless for us: it doesn't recoignize Parasolid and the nester was not powerfull enought to nest most of my jobs.
    Any suggestions or experience would be very appreciated.
    Mar 2009
    17
    try this site, that is add on or plug in for SOLIDWORKS,
    SOLID EDGE integrates very well with mastercam, and the default plane is same, SOLIDWORKS is not that is your top face of the block ends up are right side when inported in.
    This the address:
    http://www.solidnest.com/index.html
    Feb 2008
    SolidNEST for Router
    I noticed that the link above doesn't direct you to the SolidNEST website. SolidNEST is an advanced nesting solution that will optimize the way your router machine works. Try this link:
    http://solidnest.sigmatek.net/Machin...8/Default.aspx
  1. FREE 2D CAD (Solid edge)
    By ynneb in forum Uncategorised CAD Discussion
    Last Post: 05-08-2013, 11:28 PM
  2. Mastercam and Solid Edge
    By Guillaume in forum Mastercam
    Last Post: 01-28-2009, 02:25 PM
  3. graphics in solid Edge
    By Rob 1264 in forum Uncategorised CAD Discussion
    Last Post: 11-26-2007, 12:43 PM
  4. Solid Edge 2D is now free
    By bob1371 in forum Uncategorised CAM Discussion
    Last Post: 09-12-2006, 09:52 PM
  5. Which came first, Solid Edge or Solid Works?
    By Arnie in forum Uncategorised CAM Discussion
    Last Post: 09-15-2004, 12:25 PM
