Hallo
i have a problem with a Fanuc 0i-TC
After a power failure during operation ,
there is a problem with the X axis.
The x axis goes to wrong position without any alarm.
The inaccurancy is not the same every time. The mistake is from 0,1mm to 2mm.
With the jog mode there is no problem
In auto mode appears those mistakes.
i set up the cutting tool using offset.
Then the x axis get the zero points by (G00 U0 )
After this i try to cut in auto mode but there is inaccurancy in X axis
I have reloaded the SRAM but nothing changed.
how can i swap the x with z axis on the amplifier, in order to check if the problem is the ampifier?
Thank you in advance
