586,440 active members*
4,306 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > DynaCNC > Gotta DM3000 lathe, anyone interested in these things?
    Oct 2008
    6
    I purchased one of these off ebay last fall. Finally cleared out the backlog in the shop and started setting this thing up. If anyone's interested, I can document some of my "adventures" with this thing and see if we can get a bit of discussion on these older machines. Seems like a solidly built micro lathe, but it's definitely quirky!
    Mar 2009
    5
    Hi Cliff, i got given a Dyna Myte 3000 cnc lathe but i do not have a clue at my age [60] how the machine operates,i have no operating manuals so i am hoping someone out there can help me out . Cheers . axios49
    Oct 2008
    6
    I'm not Cliff, but I've got my 3000 running pretty well. I have a manual. If you can figure out how to get it copied, I could help you out. If your machine has the original controller, you really must have the manual, because the machine does not use standard G and M codes.
    In the meantime, you'll need to get a few things:
    - old computer with windows 95 on it
    - I have the utility you'll need to install on this computer
    - a serial cable and some of the modular connectors that you can get at radio shack. You have to solder up a cable (major pain in the butt) to transfer programs on and off the machine. The controller can only hold one program at a time.
    - you'll probably have to build a few things to mount tools in the turret. You can buy some of the stuff from dyna.
    Jon
    Mar 2009
    5
    Smile Dyna Myte 3000
    Hi Jon,
    thanks for your reply.My lathe has it;s original controller on a moving arm ,and a computer i can access since i work at a college and we throw heaps of them out when we upgrade, the Turret i assume you mean the rotary head that is on the .
    bed that goes back and forth [although i have not tried it]which has the 3 cutters a drillbit and a pilot drill/countersink and the serial cable is the grey cable with one end connected to a serial port on the side of the lathe. Any other info. you can provide for me will be most appreciated, regards Chris.
    Dec 2007
    6
    Also Interested
    Jon: I also have 2 of the 3000 lathes which I have not done anything with and will be watching for any insite you can give. When you indicated a cable for the computer have you changed electronics in the Dyna so that G code can be used? Does the software you have run only on a Windows 95 computer?
    Bob
  1. You Gotta See This
    By XYZADave in forum Linear and Rotary Motion
    Last Post: 03-12-2011, 12:05 PM
  2. Dyna Dynamyte DM3000 cnc lathe
    By Cliff. Johnston in forum DynaCNC
    Last Post: 05-12-2009, 02:42 PM
  3. Dyna mechtronics DM3000
    By Raskins in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-07-2008, 12:26 AM
  4. HELP! Gotta fix 2 Series 1's!
    By cabledude in forum Bridgeport / Hardinge Mills
    Last Post: 11-22-2007, 04:59 AM
  5. Replies: 3
    Last Post: 03-07-2007, 05:19 PM
