586,313 active members*
3,582 visitors online*
    Jan 2009
    servo motor selection
    am a newbee to this forum.
    My requirement is to control a hydraulic valve linear movement. Its travel is 20 mm. I need to control its position anywhere within 20 mm travel with resolution of 0.1 mm, I mean say 1.1 mm or 15.6 mm etc., The linear movement positioning is by lead screw. Calculation shows that with maximum hydraulic loads acting on the valve, 1 Nm is the maximum torque required to move the valve. Intention is to have a closed loop control with DC servo motor (24 V, current max 10A) and valve movement by LVDT feedback. I need help on:
    a. What is the DC motor rating? (torque)
    b. Brush or BLDC for effective control?
    c.Mathematical models on position control with load (web site)
    d. anyother details to be considered
    thanks in advance
    24221
    Sizing software
    http://www.electromate.com/technical...morgansoftware
    In 1:1 applications with no gearing, BLDC may show some slight cogging at very low rpm due to coarse commutation, otherwise they may be preferred due to no brushes.
    Al.
    Albert E.
    Nov 2006
    925
    An easier and more accurate way is to use a servo valve and controller card.Standard technology,available off the shelf.
  1. Motor selection help?
    By Ben Colby in forum Bridgeport / Hardinge Mills
    Last Post: 05-24-2007, 09:07 PM
  2. Servo selection
    By Tywash in forum Servo Motors / Drives
    Last Post: 03-09-2007, 03:13 AM
  3. VFD and motor selection
    By kentavv in forum Charter Oak Automation Support Forum
    Last Post: 11-28-2006, 09:35 PM
  4. Motor selection advise needed? Servo or Stepper
    By Beezer in forum DIY CNC Router Table Machines
    Last Post: 03-21-2004, 07:24 PM
  5. Motor selection
    By Konstantin in forum DIY CNC Router Table Machines
    Last Post: 03-14-2004, 07:08 AM
