586,103 active members*
3,457 visitors online*
Results 1 to 6 of 6
    6855
    mach 2 problem
    My friend was using mach 1 and it worked perfect, so than he upgraded to mach 2 and could not get one axis to work in both direction. the z and the y would move perfectly but the x would only move in one direction. What on earth could cause this? Mind you that all the hardware is working and it seam to me a mach 2 issue.
    Apr 2003
    1079
    Mach2 can be fussy with computer hardware. Did he try the special driver? There is a file called specialdriver.bat in the program folder. If this doesn't solve it, try a different version of Mach2. Version 6.11 is the current stable release, but there is a version 4.xx available too. Let us know how you get on.
    Just a thought - there are settings for direction pre-change and for pulse width in the motor tuning sections, might be worth a look?
    779
    When you uninstalled Mach1 did you also uninstall the hardware driver then reboot before installing Mach 2?
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
    6855
    Yes, that was done.
    779
    Do it again! I have had trouble many times from a funny install. And re-check your pin callouts, and HOT keys.
    Nov 2004
    118
    Quote Originally Posted by HomeCNC
    Yes, if you have the same pin for two things that is TROUBLE! Even if the outputs are not active, put in 0 for everything you don't need. I had this happen to me just the other day...
    Hope that is a little help
  1. Beginner Troubleshooting and Building Considerations
    By coherent in forum DIY CNC Router Table Machines
    Last Post: 08-13-2013, 06:05 PM
  2. Okuma LC-20 Threading problem
    By Gunner in forum DNC Problems and Solutions
    Last Post: 12-14-2011, 05:11 AM
  3. Mach 2 Estop problem
    By dentman in forum Mach Software (ArtSoft software)
    Last Post: 06-08-2005, 01:32 AM
  4. Mach 2 and settings
    By tauscnc in forum Commercial CNC Wood Routers
    Last Post: 05-25-2005, 03:05 PM
  5. Proper Computer and Chip for Mach 1
    By HomeCNC in forum Mach Software (ArtSoft software)
    Last Post: 03-18-2004, 04:14 AM
