I have two questions regarding the resetswitch on the UHU controller:
1. question: Since my controllers is mounted inside a box i want to have the resetswitch on the front panel, can i wire the reset from all the controllers in paralell to one switch? I am pretty sure this should work since they all have common ground but hopefully someone else has alredy done this and can confirm that it works.
2. question: sometimes when i turn the power off the motors start to spin untill the caps are discharged, usually about two or three turns. Can i avoid this by also pulling the resetswitch low when the power is off? Or is it better to use the emergency stop? And another thing, is this normal behaviour??
regards
Chris
