586,119 active members*
3,570 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > tool touch off and offset setting
Results 1 to 6 of 6
    Jun 2005
    1015
    we just got in a fadal 3016 with an 88 control on it. its a really low hour machine and sounds good. the setup guy is coming this morning to level and adjust the gibbs and all that good stuff, however i didnt get any manuals with the machine. can someone give me a quick run down of how to load and touch off tools. also i'm planning on running 3 vises on this machine and would like to use G55, G56, G57. how would i go about touching these off for the fadal?
    Sep 2007
    73
    Jun 2005
    1015
    i think i've read through just about every link on that page and maybe i'm missing something but nowhere did i find a procedure for touching off tools or setting up offsets.
    in my hardinge manuals they give a step by step approach to touching off tools and setting offsets. i don't know why fadal doesn't do this.
    Apr 2007
    64
    Tool Setting
    1) Install tool in the spindle.
    2) Press the MANUAL key to enter the command mode.
    3) Press the JOG key to enter the jog mode.
    4) Jog the Z axis until the tool is in the proper location.
    5) Press the MANUAL key to enter the command mode.
    6) Type SL comma and the tool number.
    7) Press the ENTER key to insert this location in the tool table.
    If the second parameter is a number other than zero, the current location of the Z axis is ignored and the current value of the length offset in the tool table is incremented by the value specified by the second parameter. For Example; If tool #1 originally has a length offset value of -10.000 and the command SL,1,-.025 is entered, the NEW offset will be -10.025.
    Sep 2007
    73
    Quote Originally Posted by Runner4404spd View Post
    Your welcome anytime
    Press the manual key type UT press enter select tool setting cycle follow the directions as prompted. This is a more fool proof way of setting the tools because it asks you what your Joe block size is and puts it in the offsets for you, no setting the length then entering the number manually for the block.
    MC
    Jun 2005
    1015
    thank you i will give these a shot today and see if i can't get some chips off this machine.
  1. Changing tool diameter in the tool offset screen
    By Vern Smith in forum Haas Mills
    Last Post: 05-09-2022, 05:25 PM
  2. K2 Tool Touch Indicator
    By tulsah in forum K2CNC
    Last Post: 06-25-2015, 03:54 AM
  3. Setting tools offset on Fanuc 21i
    By jdgromi in forum Fanuc
    Last Post: 01-08-2009, 12:04 PM
  4. I need to know exactly how to touch off a tool
    By boognish75 in forum MetalWork Discussion
    Last Post: 08-24-2008, 06:45 PM
  5. Pop-up tool touch probe
    By dmealer in forum Uncategorised MetalWorking Machines
    Last Post: 04-04-2005, 12:47 PM
