586,119 active members*
3,458 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > LB15 Spindle Motor Cooling Fan
Results 1 to 6 of 6
    Jan 2006
    121
    We recently purchased an abused '91 LB15 w/OSP5020L control. After the initial power up, we discovered the bearings in the spindle motor were bad. We sent the motor to be rebuilt. Yesterday while I was trying to get RS232 communications working, I noticed the cooling fan on the motor slowing down and eventually stopping. So I guess $650 doesn't cover bearings in the cooling fan. This morning it didn't even start and I could smell hot electric. I don't have any schematics for this machine, but I would figure there is a breaker or fuse for the cooling fan somewhere. Any ideas where specifically I should look? I know it should be in the back someplace.
    Jon
    Dec 2008
    3109
    If it is that abused,
    you should check all fans and filters on the machine,
    even the ones to the electricals.
    As a precaution, take a copy of your machine parameters now, as a backup
    Jan 2006
    121
    Good advice
    Thanks, those are good ideas.
    Jon
    Feb 2009
    19
    Be careful here. If you run this machine with no spindle motor fan you will KILL your VAC spindle drive unit. If it is a TYPE A unit and you kill it. It is NO LONGER EXCHANGABLE! Thus you just cost your company 10K to replace it with a TYPE B unit.
    Jan 2006
    121
    Don't worry, was not running the spindle, just trying to get the RS232 working. The bearings have since been replaced in the fan and it's working fine.
    Jon
    Feb 2009
    19
    Okay good. I responded to that post as well.
  1. okuma LB15
    By NJC in forum Okuma
    Last Post: 04-11-2013, 05:40 AM
  2. okuma lb15 spindle drive unit
    By TTT in forum Okuma
    Last Post: 02-03-2011, 03:49 PM
  3. Video on LB15
    By beartrax in forum Okuma
    Last Post: 08-27-2008, 04:04 AM
  4. Spindle & Ballscrew cooling system
    By Gerald Sande in forum Fadal
    Last Post: 06-07-2008, 04:16 PM
  5. okuma LB15 spindle drive unit
    Last Post: 03-17-2008, 12:51 PM
