586,106 active members*
2,987 visitors online*
    Mar 2007
    85
    CNC4PC Breakout Boards
    Hi.
    I am looking at buying a breakout board for 4 x Gecko G251's.
    The CNC4PC C11 looks like the good candidate in my case.
    My concern is,will it be able to drive 4 separate stepper drivers? (They say it has pin's 2 to 9 for output. Is that 2 pin's per driver?)
    Any insight into this issue will be greatly appreciated.
    Best Regards,
    Bert.
    Jul 2007
    887
    Yes, the C11 will drive four drives directly. Two pins per drive, one for step and one for direction are available on the C11. On top of that you also have access to pin 1, 14, 16 and 17 which are shared between functions on the board such as the chargepump, relays and F/V converter for analog output and of course the 5 input pins for home switches etc.
    Mar 2007
    85
    Quote Originally Posted by H.O View Post
    Thanks for the info....
  1. CNC4PC C10 breakout board.
    By spaceballs_3000 in forum Benchtop Machines
    Last Post: 05-02-2008, 09:10 PM
  2. Replies: 2
    Last Post: 01-24-2008, 11:33 PM
  3. CNC4PC Boards
    By tz1238 in forum CNC Machine Related Electronics
    Last Post: 11-03-2007, 05:55 AM
  4. 2020 drive with cnc4pc breakout board
    By najnielkp in forum Servo Drives
    Last Post: 02-28-2007, 06:34 AM
  5. breakout boards
    By Gads in forum CNC Machine Related Electronics
    Last Post: 03-06-2006, 12:39 AM
