Have a Torq cut 22 I'm trying to revive. I bought it in as is Parts only condition. So far everything has come alive and started working except for the gear changing. I have another Torq cut but it does not have the transmission so I have nothing to compare.
When you grab the spindle with your bare hand is there slop rocking back and forth? I can feel looseness back to the gearbox I believe on this machine. I cannot imagine that that is good.
I'm also having issues with it shifting gears. At first it was in low gear and I could run the spindle. I tried to run at higher RPM but I would get a time out for the high low switch. I checked the oil over the transmission and topped it off. Now it is in neutral it is somewhere between high and low and I cannot get it to go either way.
I have tried some of the suggestions that I have found here in the forms with no success. Does anyone have any recommendations beyond pulling the motor.
Sent from my SM-G955U using Tapatalk
