586,042 active members*
3,686 visitors online*
Results 1 to 8 of 8
    Feb 2005
    154
    Bridgeport Interact 412
    A friend of mine is thinking of buying a 1989 Bridgeport Interact 412 with a Heidenhain control.
    Can you still buy parts for this machine and is the control still supported by Heidenhain? Is this a pretty decent machine or one to be avoided? What are the pros and cons??
    Any input would be appreciated.
    Thanks, Pete
    1121
    re
    The control is still supported by Heidenhain
    As with any 20 year old machine, some stuff is available some isn't
    The demise of Bridgeport means not as much is around that could be.
    To me the sweet spot for age/value is about 10 years. VMC's are fairly cheap nowadays, so he might consider a newer one.
    On the upside, the control is pretty bulletproof[I think it would be a 151 or 2500] and well supported.
    Feb 2005
    154
    Thanks Gus,
    I agree, I have been trying to talk him into a larger and newer machine and I haven't had any luck. He prides himself in being able to fix em. I will relay the information.
    Thanks again, Pete
    Apr 2010
    Post bridgeport interact 412
    I need a help to find out a coolant pump or wiring details of bridgeport interact 412 CNC machine.
    My old pump get burned and i couldnt find a replacement. I bought a new single phase pump and its not working. So please help to find out a replacement of coolant pump or wiring details for compatable pump.
    Please... I am new in this field.... please help....
    Jun 2019
    Re: Bridgeport Interact 412
    Quote Originally Posted by Gncc50 View Post
    Thanks, Pete
    Hello i have a bridgeport interact 412 and it works really fine, las week the machine lost parameters does any one have the parameters im on a hurry please.
    Jun 2019
    Hi im from mexico and i have a bridgeport interact 412 and last week my machine lost parameters and i dont have a back up does anyone has the parameters ?
    Jun 2019
    Re: bridgeport interact 412
    Hello i used to have a problem with the pump and i buy a pump and installed on the relay that activate when you put the code M08 maybe thats why its not working if you dont use the correct relay. I have a problem with parameters can you help me with a image of your parameters of your machine ?
    Jul 2019
    VMC's are relatively cheap so you may consider taking a new one.
    happy wheels
  1. bridgeport interact 520
    By goodmancncgcode in forum Bridgeport / Hardinge Mills
    Last Post: 04-03-2013, 02:53 AM
  2. Bridgeport Interact 1 MK 2
    By cevyil in forum Bridgeport / Hardinge Mills
    Last Post: 01-19-2012, 05:21 PM
  3. Bridgeport Interact 1 MK 2
    By tommo61 in forum Bridgeport / Hardinge Mills
    Last Post: 12-23-2011, 04:34 PM
  4. Bridgeport interact 412
    By la1508 in forum Want To Buy...Need help!
    Last Post: 07-09-2010, 10:52 PM
  5. Interact 308 Bridgeport ?/:????
    By SGARCIAM in forum Bridgeport / Hardinge Mills
    Last Post: 08-21-2008, 10:22 PM
