You should check you e-mail before you post slander like this. The following message was sent to you on January 22, 2009, with the attachments indicated. Maybe your spam filter is set to filter out information that you need.
This board has the same electrical rating as the current production board.
Fred Smith - IMService
Dear Joe,
I will try to help you, but we don't have much available anymore. The owner should have had papers that show the connections, you may want to double check with him.
It is extremely important that there must be a common ground between the Logic supply and the Motor Power supply. The logic ground and power ground must be the same. If this is not done correctly it could damage the board.
I have attached the only information still available. We no longer support these servo drivers.
This is a servo driver we stopped selling in 2004. The replacement is :
http://www.imsrv.com/deskcnc/#servo
We don't sell breakout boards. We sell the DeskCNC software and control board. We also sell Mach3, but not a board for it.
