586,094 active members*
3,914 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Corel to Autcad Text trimming
    Nov 2008
    130
    I am having troubles drawing up a sign using ovals and text in corel, and then saving as dxf or dwg and opening in autocad to trim out the lines needed to allow the parts to stay together when cutting, but I am having problems with the trimming. Some letters trim just fine to the oval outline, but others, it deletes half the letter!!!??? Whats going on, anyone have a fix?
    Oct 2005
    40
    Once you bring in the .dxf file in to autocad go to the express menu then text then explode text click on this then window the text this will explode the text then use the explode comand and window the text agian then hit enter
    now you can trim extend or add lines.must have autocad ver2007-2008-2009 There is a express menus for older ver from the internet look for express menus.
    If the text from Corel is made up of splines, that could be the problem. I've seen similar occurences when trimming splines. Unfortunately, I don't really have an answer. If they are splines, you could try a spline to polyline conversion lisp and convert to polylines before trimming.
    322
    Try the DXFTool
    Try the DXFTool for CorelDRAW. It is currently sold by CandCNC.com
    -James
    James Leonard - www.DragonCNC.com - www.LeonardCNCSoftware.com - www.CorelDRAWCadCam.com - www.LeonardMusicalInstruments.com
    Oct 2005
    40
    If the text from Corel is made up of splines,In autocad save the file as wmf this will explode the splines.
  1. Autcad UCS trick
    By wjbzone in forum Autodesk
    Last Post: 03-22-2022, 12:24 PM
  2. Problems exporting Corel text files as DXF
    By CustomConcepts in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 10-21-2008, 07:24 PM
  3. router trimming
    By snocutt in forum Employment Opportunity
    Last Post: 08-21-2008, 06:46 PM
  4. Trimming in bobcad
    By Parameter in forum BobCad-Cam
    Last Post: 12-30-2005, 10:07 PM
  5. DXF export from Corel - Text cutting
    By maxxgraphix in forum G-Code Programing
    Last Post: 03-24-2005, 04:12 AM
