Hello ALL!
Just ran into a problem when I view or post code the tool change come in with a negative move as discussed bellow.
In FANUC 11T POST
Under FORMAT “TOOL CHANGE” I have the following information.
G97S<CALC-SPEED><SP-RANGE><EOB>
<MOTION>X<X-RETURN>Z<Z-RETURN><SPINDLE><EOB>
T<$TOOL>00<EOB>
M01<EOB>
N<TOOL>G50S<SP-MAX><EOB>
T<TOOL><OFFSET#><EOB>
{<MOTION>}X<X-COORD>Z<Z-COORD><COOLANT><EOB>
<IF><CSS-ON><THEN>
G96S<CSS-SPEED><EOB>
<ENDIF>
G04U2.<EOB>
This results in the below G-CODE output with an X-axis –11.0092 move that drives the turret down to the over travel and stops the machine.
G97S450M42
G0X--11.0092Z3.4908M3
T0300
M01
N06G50S4000
T0606
X6.45Z0.0349M8
G96S760
G04U2.
Any ideas as to what I am doing wrong?
