586,089 active members*
3,820 visitors online*
    Apr 2005
    108
    adjusting the tool setter on M32
    We have a lathe with M32 control and we had a crush
    I need to adjust the tool setter
    When I measure the tool and cut with this tool I have
    Difference of 0.21mm between the part that I check and
    What I got on the screen did someone know how to adjust it
    Dec 2007
    36
    crash
    First off, do you have a lathe or a mill. You said lathe, but you also said M32.
    The M in M32 is for mill, otherwise it is a T32, T for Turning. If you guys had a crash, did you fix whatever moved in the crash. If so, then the easiest fix is to use tooleye comp in the tool data. For a more permanent fix you will have to adjust the parameters that control the position of the tooleye. If this is a lathe, are the od's big, and the id's also big? have you pulled taper on the headstock to verify that the spindle is still inline with the z-axis ways? Many more questions?
    Mikiemo
  1. Tool Setter Macro for M-V60C and Metrol Setter
    By mitshack in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-02-2013, 12:08 PM
  2. Tool setter macro for M-V60C and Metrol setter
    By mitshack in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-06-2008, 02:38 PM
  3. TOOL SETTER WITH G50???
    By DublJ in forum Fanuc
    Last Post: 07-30-2008, 01:28 PM
  4. Tool Setter
    By GARY DAVIS in forum Fadal
    Last Post: 03-19-2008, 01:44 AM
  5. tool setter
    By ACME in forum MetalWork Discussion
    Last Post: 07-30-2005, 05:15 PM
