586,100 active members*
3,096 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > How much do you charge for plasma cutting time?
Page 3 of 3 123
Results 41 to 50 of 50
  1. #41
    Feb 2006
    133
    Smile
    Looks promising....... You have my interest!
  2. #42
    Dec 2004
    312
    i have hired a php programmer to code simlar script for my website to give price quote
    if someone else is interested in this script ill find out how much he wants for the code..
  3. #43
    Feb 2011
    I use 14ga mild steel sheet. For this guage I multiply the amount of cutting inches, BEFORE I click for the final cutting vectors, by .2[20 cents per inch] for metalart and .04[4 cents per inch] for repetitive parts. The metalart takes so much more time to clean up that it justifies the higher cost/". This is all at 260"/min. The heavier the material, the slower your cut speed. Find a good cut speed for your thickness and do the math to tie it in to your hourly shop rate. I have a digital catalog with over a hundred items and all of them are priced by the pre-cut-path inches X .20. But it's only good for 14ga. If a customer wants thicker stuff then a study has to be done to see what the new cut speed is and how much of it you can do in one hour.
  4. #44
    Aug 2010
    cnc plasma costing?
    hey friends. i have cnc plasma 1250 hypertherm make. i want to know what factor to be considered while getting the per ft or per inch cost to be quoted to the customer. i am trying to find it on this forum but searching and searching and not getting it. If anyone can please send the link to that forum or if anyone can help me find the cost per cutting for hypertherm cnc plasma 1250, that would be of gr8 help.
    i cut mild steel as well as stainless steel squares and circles majorly.
    thanx
  5. #45
    Jan 2012
    sir....you can use fastcam software,this software already have you can make nc codes and make quotation for the exact price for the plasma cutting....
  6. #46
    Aug 2010
    I DONT GET YOU
    Quote Originally Posted by spawn_818 View Post
    DEAR SIR
    I BEG YOUR PARDON , BUT I DINT GET WHAT YOU MEAN. I HAVE FASTCAM SOFTWARE, N I MAKE NC CODES TOO, BUT HOW IS THAT GOING TO HELP ME QUOTE THE PRICE FOR CUTTING.. I KNOW HOW MUCH METER DO I CUT, BUT WHAT SHOULD BE THE PRICE BREAKUP.. CAN YOU PLEASE PUT SOME LIGHT ON THE SAME..
  7. #47
    Jan 2012
    sir use fastcam costing,its already in the software,if you already have nc codes,then it its easy to input, no matter how big or small or how much meter,it is.,fastcam and fastnest can compute,the price for cutting and area that you will use ,do you now how to use it....?and what is the version of your fastcam?im just trying to help you.
  8. #48
    Jul 2007
    54
    Hey all,
    great info as I'm very new to pricing items.
    Question for you all
    I have a job that I need to price out, the pieces are 3/8" thick 13"x66". The plate has 427 pierces in it and a cut of 1359".
    I'm guessing the material cost will be in the 450 dollar range..
    with this information what would your estimates be on pricing this job?
    Would you still double the price of the material even as the material gets more expensive?
    and jim said his charge for 3/16" steel was .75 would that price go up for thicker metal than the 3/16"?
    thanks in advance.
  9. #49
    May 2012
    Where I work we charge 200 a hour for up to a inch thick. Then add 100 per inch after that with top out at 400 a hour. One hour minimum. Its cheaper if we bid the job cause we factor in a cheaper cut costs then. Thats with simple cad work and beveling. I do a lot of power plant work so I guess when a power plant is loosing 100k every few hours they can pay those rates.
  10. #50
    Jan 2006
    Re: How much do you charge for plasma cutting time?
ID:	241720Click image for larger version.
    Here is a simple program i put together to help me with quoting.
Page 3 of 3 123
  1. What to Charge for Plasma Cutting Services
    By rescueweasel in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 01-11-2022, 02:35 PM
  2. How much to charge for CNC plasma time?
    By dsmdude in forum Employment Opportunity
    Last Post: 03-04-2015, 05:04 PM
  3. Replies: 14
    Last Post: 03-07-2010, 03:24 PM
  4. CNC Plasma Charge
    By cosmiccutting in forum Waterjet General Topics
    Last Post: 03-23-2007, 11:33 PM
  5. Charge for Laser Cutting...
    By sntlewis in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-18-2007, 05:48 PM
