586,909 active members*
3,380 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Issue with cutter comp with G68 active
    Aug 2005
    36
    Good morning folks (At least it is a snowy morning here in UK)
    Running Fanuc 18i on Enshu JE60.
    I have a proven program finish milling around two internal overlapping circular cavities. Works fine, no problem. Problem starts due to a fixture issue, where I need to use co-ordinate rotation to make minor correction for the fixture (This error cannot be corrected on the fixture without serious cost and downtime). When I rotate the feature, I get 041 CRC Interference error, and after experimentation, I have to reduce radius of tool by minimum 4mm for it to run (Tool radius is 12.425), but it runs round fine without the G68. Section of program posted below. There are plenty of variables at the start, as this is a 3 per load fixture and we loop to save memory, most of the variables relate to work offset selection, speeds/feeds, safety checks etc. and don't have any bearing on the milling section.
    Those that are relevant are #120 (Rotation angle) this varies across each station, ranging from -0.114° min to +0.153° max, so only minor change in angle. #110=0 in this case (Optional adjustment in centre distance).
    What's really confusing me, is that with no G68 line, the program runs perfectly, I don't get why the rotation should upset it as obviously all the start and end points are equally rotated, unless I have a parameter issue.
    I've highlighted in BOLD the line where I get error in single block (To avoid read ahead buffer), it runs fine up to there.
    Anyone seen anything like this before?
    Cheers
    N16M6T16(25MM - 3 FLUTE FLY MILL)
    (MILL COVER FACE & GEAR CAVITY BOTTOMS)
    M35
    M1
    T15
    M52
    #112=1.
    #113=350.-[760.+#[#112*20.-20.+7003.]]
    WHILE[#112LE3.]DO1
    #114=#112
    IF[#1001EQ1.]THEN#114=#112+20.
    #101=315.
    #102=3.*.025
    #103=25.
    #104=#101/[#103*3.142/1000]
    IF[#104GT13000.]THEN#104=12950.
    #105=#104*#102
    #120=#[#112+120.]
    IF[#1001EQ1.]THEN#120=#[#112+140.]
    G69
    G0G90G54.1P#114
    G68X0Y0R#120
    X-[25.4+#110]Y0S#104M3B0.G43Z#113H16
    Z2.M8
    (M51)
    G1Z-8.8F2000
    Z-[11.006+#100]F#105
    X0Y0
    G41X12.767Y0D16
    G3X-14.733F#105Z-[11.012+#100]R13.75
    G3X-14.733I14.733
    G3X12.767R13.75
    G40G1X0Y0
    X-[25.4+#110]Y0
    G41X-[38.167+#110]Y0D16
    G3X-[10.667+#110]Y0R13.75
    G3X-[10.667+#110]Y0I-14.733
    G3X-[38.167+#110]Y0R13.75Z-10.962
    G40G1X-[25.4+#110]Y0
    G0Z.05
    (COVER FACE )
    #102=3.*.075(FEED )
    #105=#104*#102
    G3X-25.4Y26.75Z0R13.375S#104F#105
    G3X-12.700Y-23.543R-26.75
    G3X-12.700Y23.543R-26.75
    G3X-25.4Y26.75R26.75
    G3X-25.4Y0R13.375Z0.5
    #113=10.
    IF[#112EQ3.]THEN#113=350.-[760.+#[#112*20.-20.+7003.]]
    G0Z#113
    #112=#112+1.
    END1
    G69
    M9
    M19
    G91G30X0Y0Z0M80
    G90
    Why, Oh why am I always in trouble?
    Aug 2005
    36
    Update, work around found.
    Found a work around.
    It only seems to be struggling with the 360° circle line using the I value, so I split that into 2 x 180° arcs and went with an R value instead, that works no problem.
    Experimented with adding J0 to the G3 line, Z0 to the G68 line prior to finding that, none of which helped.
    Strange!!
    I think it must be a Fanuc thing.
    Sorted, but would still like to understand why it failed, so please still post if you have any thoughts.
    Cheers
    John
  1. Cutter comp issue Yasnac MX3
    By Dualkit in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-26-2009, 09:22 PM
  2. Cutter comp on an id hole< cutter diam.??
    By PaintItBlue in forum Haas Mills
    Last Post: 05-06-2008, 12:30 AM
  3. Cutter Comp?
    By donl517 in forum Fadal
    Last Post: 07-03-2007, 02:36 PM
  4. Cutter Comp.
    By Big"E" in forum MetalWork Discussion
    Last Post: 03-28-2007, 05:05 PM
  5. 18-it cutter comp
    By newcinhypro in forum Fanuc
    Last Post: 01-26-2006, 03:00 AM
