586,061 active members*
4,540 visitors online*
Results 1 to 12 of 12
    Feb 2009
    Angry Needed: Amada Alarm Code definitions!
    One of my other plants just got an Amada CNC Punch machine and they are having a little trouble using it. They have a program that gives them an alarm code "Pitch 147". I cannot figure out what that is. And they are on the other side of the country. So I am looking for a list of the alarm codes for the Amada machine. Its not in the manual. I cant find it online. Im stuck with them until I can figure out what that alarm code means. Please help! Thanks!
    Kevin
    Sandusky Cabinets
    Apr 2007
    64
    I don't know anything about punch presses but I did Google "pitch 147 amada"
    and came up with this. Look at page 2.
    http://www.amada.com/support/service...?file_id=15971
    Jun 2010
    Quote Originally Posted by SanduskyCabinet View Post
    Kevin
    Sandusky Cabinets
    hi. whats the control of your machine.
    I work only with amada press punch machines
    Jun 2010
    gime me the control number of you machine. I work with amada press punc machines.
    perhaps I can help you
    Jun 2010
    gime me the data of your machine. perhaps I can help you
    Oct 2006
    975
    Kevin
    Sandusky Cabinets
    Hello Kevin,
    I don't know what model Amada turret punch they are using, but my Vipros alarm list has alarm 147 listed as below:
    Oops, I didn't see this was an old post until after replying. No big deal.
    147 An excessive pitch is instructed for nibbling.
    I imagine the program is trying to use an excessive pitch for the tool that is nibbling a profile etc. , so try reducing the pitch for that tool to a percentage of the tool length(say 75% etc. as I forget the actual recommended %) or smaller if that does not work.
    I hope this helps, but seeing the actual g-code might help.
    Regards,
    Wes
    Jun 2010
    isn is a vipros 358 kII?
    Oct 2006
    975
    Hello,
    Yes this is from an Amada Vipros 358K/368K operators manual
    Regards,
    Wes
    May 2016
    26
    Re: Needed: Amada Alarm Code definitions!
    Anyone Alarm 2255 on a Amada 2510V Apelio III, this alarm appears every time it punches, even in MDI mode. It is a PHNC alarm 17: that it says B.D.C error, Details: Servo tolerance is over the limit while hitting the B.D.C.....
    Any ideas
    May 2016
    26
    Quote Originally Posted by hiramfs View Post
    It is a Apelio III laser punch combo, the controller is a Fanuc Series 160i Leatherman.
    Still getting the alarms in the PHNC; alarms 10 and 17
    The main alarm in the Fanuc control is 2255.
    Oct 2005
    89
    Quote Originally Posted by zagpaz View Post
    Any ideas
    hi there,
    Is your machine problem resolved..?
    are you still looking for solution ?
    Apr 2023
    Tengo una punzonadora amada con el error index no preparado (interlock), el error lo da casi siempre a la misma hora y aunque apague la maquina 4 hora y la prenda no funciona hay que dejarla al dia siguente para que pueda funcionar
  1. Amada OLC Alarm List
    By Bryden in forum Machinery Manuals / Brochures
    Last Post: 01-11-2012, 02:03 AM
  2. Amada Pega344 g-code
    By mnadi121 in forum G-Code Programing
    Last Post: 05-28-2011, 09:17 AM
  3. Amada king 2510 stop button alarm
    By RacerX1 in forum Fanuc
    Last Post: 09-11-2010, 09:01 PM
  4. Nisshinbo CNC code & Amada LASMAC 667 II
    By Independent CNC in forum Waterjet General Topics
    Last Post: 09-16-2006, 11:00 PM
  5. G-Code letters What are the definitions?
    By CADkathy in forum G-Code Programing
    Last Post: 08-05-2004, 12:37 AM
