586,043 active members*
3,643 visitors online*
Results 1 to 7 of 7
    Nov 2004
    56
    Mach 2 safe limits ?
    can you set the safe limits in Mach 2 to keep from over travel on machines without limit switches.....or is this for something else...I read the manual but it does no go that deep into it......... :cheers:
    Oct 2003
    593
    Mach2 has a soft, (software only) limit option. I tried it but it doesn't work that well unless your machine starts from the same position every time. Or you reset the soft limit values each time. It depends on where your toolpath starts.
    Buy some switches and wire. Much better and safer.
    Regards Terry.....
    Nov 2004
    56
    I was thinking you could set the table in the middle and call this X 0 Y 0 and bring the Z up to a safe distance and call it Z 0.....then set your soft limits around .200 or so from over travel in each direction....Then use G54 and G43 in all your programs.....would this work or am I missing something
    Nov 2004
    56
    I posted this in Mach2 yahoo group...and Art said this would work.
    Try it........... :cheers:
    Oct 2003
    593
    Yes, the theory is good, but in practice I had to keep altering settings when cutting different height materials. Also with no home switches the X/Y =0 position is not repeatable. You have to guess the table centre. No good if you're using jig fixtures. If it's working for you, great.
    I still have no home/limit switches, but I do plan on adding them. I also stopped using the softlimits. I visually place the cutter where I want to start. Then reference all axis home before starting the program run. I've had no problems with overtravel YET, but I would like a repeatable reference position.
    Regards Terry.....
    http://www.terry-is.f2s.com/
    Nov 2004
    56
    I am waiting for my Mill to arrive.....just kinda thinking out loud right now...I will try some stuff when it comes.....Thanks
    Jun 2003
    1365
    I am new with mach2, just bought it last night and I tried to set up soft switches and it really doesnt even read them, any suggestions?
    Jon
  1. Replies: 14
    Last Post: 01-15-2010, 02:06 PM
  2. Mach / geckos or DTLLC drivers
    By zcases in forum Mach Software (ArtSoft software)
    Last Post: 01-12-2007, 02:06 AM
  3. Mach 2 and settings
    By tauscnc in forum Commercial CNC Wood Routers
    Last Post: 05-25-2005, 03:05 PM
  4. Mach 2 slow on Intel Centrino P1.6 Notebook
    By daddyhobby in forum Mach Software (ArtSoft software)
    Last Post: 03-28-2005, 02:33 PM
  5. Proper Computer and Chip for Mach 1
    By HomeCNC in forum Mach Software (ArtSoft software)
    Last Post: 03-18-2004, 04:14 AM
